Cab Lights install
Old Nov 4, 2008 | 08:24 AM
scheer89's Avatar
scheer89
Cab Lights install
I just installed a set of cab roof lights.. i want them to connect to the regular light switch but can't figure it out. someone said to connect them to the fuse box but i don't wanna try that.. any help would be great thanks guys
Old Nov 4, 2008 | 02:47 PM
ReAX's Avatar
ReAX
2000 Ford F Series Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Red/Black or Blue/Green Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Ignition 3 Dark Red/Black Ignition Switch Harness
Accessory Gray/Yellow or Blue/White Ignition Switch Harness
Tach White/Pink BCM, Pin 48 of 104 Pin Connector or Pin19 if Diesel
Neutral Safety Wire Red/Light Blue Ignition Switch
Brake Switch Red Brake Switch
Trunk Pin n/a
Parking Lights Brown (+) Driver's Kick Panel or Light Switch
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple(-) Driver's Kick Panel
Door Trigger Black/Blue (+) 40 Pin Connector Firewall behind Driver's Dash
Door Lock Pink/Yellow High Driver's Dash Negative Trigger w/Keyless Entry
Door Unlock Pink/Light Green Reverse Polarity w/o Keyless Entry
Driver's Lock Pink/Black Driver's Door Boot
Driver's Unlock Red/Orange Driver's Door Boot
Passenger Unlock Pink/Orange Keyless Module
Horn Wire Dark Blue (-) Brown 6 Pin Connector behind Driver's Dash
Windows Up LF=White/Black, RF=White/Yellow, LR=Gray/Orange, RR=Yellow/Black
Windows Down LF=Orange/White, RF=Tan/Light Blue, LR=Yellow/Light Blue, RR=Red/Blue
Pull out the head light switch and tap into the brown wire.
Old Nov 4, 2008 | 03:27 PM
scheer89's Avatar
scheer89
good call. .thank you.. im saving all these specs by the way
Mcald62
Oct 22, 2016 10:53 PM
Mcald62
Electrical Systems/Wiring
Sep 21, 2016 06:39 PM
blk450er
Jun 4, 2016 08:48 PM
geearturi
Aerostar
Jul 1, 2015 08:34 PM
irly
6.7L Power Stroke Diesel
Jul 28, 2014 10:06 AM
