Sponsored by: Real Truck
inactivate auto door lock
Old Nov 3, 2008 | 08:35 AM
carlsbaded's Avatar
carlsbaded
Hello! I'm new to this forum and could not find anything about this subject. Can anyone tell me how to inactivate or de-commission the automatic door locks on my 2002 F-350 (4X4 supercab)? Thanks
Old Nov 3, 2008 | 09:46 AM
riggz's Avatar
riggz
Post
On page 64 of the owner's manual ( https://www.motorcraftservice.com/pu.../02f23og5e.pdf ):
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
