Manual Choke
Old Nov 2, 2008 | 08:04 PM
kjmdrumz3's Avatar
kjmdrumz3
Manual Choke
'77 Ford F-250 6.6L. Wanna install a manual choke because of the choke problems I've been having. Where can I find a choke that would work?
Old Nov 2, 2008 | 08:34 PM
TexasRho83's Avatar
TexasRho83
Any universal choke kit will work. O'Reilly's, Autozone, NAPA, take your pick
Old Nov 2, 2008 | 08:42 PM
fmc400's Avatar
fmc400
MSEE
You can get a manual choke kit at most parts stores for about $20. I usually see them in the "Help!" section. The kit comes with the choke cap, cable, bracket, and anything else you need.
Old Nov 2, 2008 | 08:45 PM
TexasRho83's Avatar
TexasRho83
Yeah you can sometimes get away with not even drilling a hole in your firewall for the cable. Just find a pre-existing one for other wiring projects or sometimes you can even squeeze it through the hole for your steering column (lol)
Old Nov 2, 2008 | 09:46 PM
kjmdrumz3's Avatar
kjmdrumz3
Thanks guys
Old Nov 5, 2008 | 03:28 PM
77FordTruckMan's Avatar
77FordTruckMan
I got one of those kits, but it was junk so i used it for a while and switched back to the automatic because it barley worked at all. I got mine from jc whitney for $11
Old Nov 5, 2008 | 08:04 PM
80F100man's Avatar
80F100man
I had a manual choke and it broke apart, would this cause any problems on say, top end or bottom end performance, I've just left it apart, it starts ok if you pump it enuff .....could this create a 'too much air' problem?
Old Nov 5, 2008 | 08:05 PM
TexasRho83's Avatar
TexasRho83
Nah it's only necessary for starting reasons. If you can do that w/o a choke then all the better
fordboy300
28
Mar 9, 2012 10:59 AM
cruisers4wdtoy
21
Apr 4, 2006 01:40 PM
danimal
Feb 25, 2004 10:36 AM
Sedric
Oct 7, 2002 08:35 PM
