Look Ma!! No stands!!
Old Nov 2, 2008 | 07:23 PM
BACAGrizz's Avatar
BACAGrizz
More progress on the home front, or is it rear?
Got the boxing plates finish welded and ground and mounted the Shockwaves yesterday. It is now suspending itself. Yay!!!
More views in my November progress gallery.
The welds may not be very pretty but they are strong. The 2x4 x-member is 1/4" thick rectangular tube steel. The comealong strap keeps the rear cross member in place and stops the frame rails from spreading untill I can bolt it and the fuel tank brace in.
That part of the project is a little further down the road.
Old Nov 2, 2008 | 08:11 PM
mechmagcn's Avatar
mechmagcn
Looks good, keep it up and it'll be back on the road soon.
Hey, were you one of the members manning the BACA booth at the Robber's Cave Fall Festival?
Old Nov 2, 2008 | 08:22 PM
BACAGrizz's Avatar
BACAGrizz
Baca
"Hey, were you one of the members manning the BACA booth at the Robber's Cave Fall Festival?"
Not this year. That would have been our McAlester Chapter. I have been down there a few times to support them with Level I rides and such.
I keep threatening to get down there for the foliage cruise but haven't made good on the threat yet. Maybe next year. Maybe even with the truck.
Old Nov 2, 2008 | 08:27 PM
mechmagcn's Avatar
mechmagcn
Come on down! If the show keeps growing, they will have to find some more room for it, there were 505 vehicles this year. We had a ball showing off the 53 and my home made teardrop trailer.
Old Nov 3, 2008 | 04:54 AM
52'F-3's Avatar
52'F-3
i checked out the gallery also, looks like a really nice job...........
i like the 4-link.
Old Nov 3, 2008 | 08:46 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Woohoooo!! Cold frosties all around!
Bobby
Old Nov 3, 2008 | 09:39 AM
sdetweil's Avatar
sdetweil
looks awesome!..
note that for airbags/springs, when you get closer to road time, you either need TWO valves per bag (1 up and 1 down), OR you need 2 valves total shared (one air line to both bags), 1 up and 1 down AND a sway bar to keep the air from flowing between the bags on turns.. (I didn't know that on my airbag rear with 1 shared valve setup)
Sam
Old Nov 3, 2008 | 10:22 AM
BACAGrizz's Avatar
BACAGrizz
1 up and 1 down AND a sway bar to keep the air from flowing...
Yeah, the schrader valve kit is temporary. I plan to have separate valves for each side in the rear and a sway bar also.
I have given up on trying to adapt the E-250 front sway bar to the rear. Too wide for the tires an wheels I want to use. Now that the leaf springs are not there, the plan is to tub the bed and then I can tuck wider wheels under there and keep them within the fenders. That calls for a different sway bar setup.
The search continues for suitable equipment.
Old Nov 3, 2008 | 10:35 AM
sdetweil's Avatar
sdetweil
I used a Hotchkis 7/8in Camaro bar in the back, about 2 inches narrower than the chassis at the rear axle. short arms.. (room inside my triangulated rear) I bought a couple heim racing drop links and drilled thru the frame & boxing plate to provide the chassis side bolt.
I found one used (never installed) for about $150.
Hotchkis Sport Suspension - Sport Sway Bar (R)
Sam
Old Nov 3, 2008 | 11:02 AM
rockher_man's Avatar
rockher_man
Thumbs up right on...
...that's some "top-shelf" fabricatin' ther GRIZZ...congratz...
Old Nov 3, 2008 | 12:41 PM
mechmagcn's Avatar
mechmagcn
Check out the rear bar for a 88 Bronco II, it is nearly a bolt-in fit. There is a pic of the one that I used in my gallery.
Old Nov 3, 2008 | 02:12 PM
BACAGrizz's Avatar
BACAGrizz
By golly, I think it will work!! I need to hit the local wrecking yard for a few measurements!
Thanks a lot!
Old Nov 4, 2008 | 09:45 PM
BACAGrizz's Avatar
BACAGrizz
Your rear end. (Or rather, your trucks!)
That Lincoln diff you have, is it symmetrical? It looks like it in the picture in your gallery. My old 9" is not. The pumpkin is offset to the passengers side by an inch or two. See my gallery for the August progress pics and you can see how much offset it is.
Now I am thinking that bar from the Bronco II may not work. It appears a bit narrow in the arch that goes around the pinion support. I would have to offset it to the right I think. Either that or get creative with the mount and attach it to the frame or a cross member instead of the Diff.
Number Dummy says the diff in my truck is a 1965 HD unit. From a T-bird, station wagon or police cruiser.
I may end up having to use some sort of torsion bar like they have in sprint cars that attaches to the frame behind the shockwave x-member and goes around them on the outside wtih arms that mount to the diff outside the frame rails.
Old Nov 4, 2008 | 11:43 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Looks great, Grizz!! You've been busy since I've been there...wish I could say the same. I got the axle out of my rear end tonight, and it has 3" brakes. Hmmm. NAPA doesn't show a 3" on a F250 - just on an F350. So, perhaps I have a 350 rear end. Guess I'll have to check the numbers on the tag - I know it came off of a 250, so guess it's been changed before. Can't see any reason it won't work - the spring perches are identical, and the width is correct. Maybe some drive shaft difficulties, but I have to shorten it anyway. But, if it will work, it will be nice, because the drums are freshly turned!
Great work - keep it up. Who knows, maybe we'll be able to "go out in style" next time I'm out there!
R
Old Nov 5, 2008 | 06:42 AM
mechmagcn's Avatar
mechmagcn
Yes it is, but the bar is not centered on mine. The RH mount on the axle tube is about 2" from the center section.
