Radiator cap pressure
Old Nov 2, 2008 | 06:01 PM
edzakory's Avatar
edzakory
I didn’t want to hi-jack a thread on cooling but it raised a concern about radiator caps.
<o></o>
I believe that raising the pressure of the cap can help reduce water temperature but I did not know the reason for the various cap pressures.
<o></o>
I have the old stock radiator with the big brass tank. The old radiator cap went bad and I replaced it with a 13 lb cap that I had from old parts. Soon after installing, I noticed a leak. It turns out to be a split in the brass tank. I was able to repair the split and but didn’t dwell on the cause.
<o></o>
F6Guy posted that you should not use a high pressure cap on the large brass tanks.
<o></o>
The 13lb cap is awaiting destruction upon your confirmation.
<o></o>
<o></o>
Old Nov 2, 2008 | 06:50 PM
reg1952's Avatar
reg1952
For every pound you increase in pressure it raises the boiling point 3 degrees of water temp.So you may not boil over but you put alot more stress on these old rads. I would go down in presure to save the rad.
Old Nov 2, 2008 | 08:25 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Edzakory,
Yep, like we discussed in the other thread and REG1952 mentioned there's a bell curve here - not enough pressure, over heat and boil over - too much pressure - blown seams. It's hard to find the top of the curve sometimes. I guess that's one of the reasons I have the radiator and the (despite the "off" function I'll use the "politically correct term") surge tank with different ratings of caps.
13 pounds blew my seams too and I don't have a stock radiator. So I went to 7 pounds and still had a problem. But my system is designed and configured differently to handle quick heating as I explaned over there.
Try the 7 pound cap and it should be ok. If not you can go to 4 pounds and raise the % of coolant to water in your mixture by 15-25%. It probably wouldn't hurt you to try that anyway out there in AZ.
Ok that's all I'm saying - tee hee!
J!
