1992 4.9l wont start help
Old Nov 2, 2008 | 12:15 PM
212nut's Avatar
212nut
1992 f-150 4.9l. great spark, had tank full of water, drained, replaced filter, filled with fresh gas, new plugs and fuel pressure regulator. fires great on starting fluid. pressure test is 57psi with key on, turn over engine it stays around 57psi, doesnt apear to bleed down. need help, ready to pull my hair out.
Old Nov 2, 2008 | 01:17 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Sounds like you lost the injection firing. Maybe lost the path to ground. thats how they're actuated. Do a KOEO scan probably cough somthin up.
Old Nov 2, 2008 | 01:20 PM
212nut's Avatar
212nut
did a scan the only thing that came up was a coolant temp too low or too hhigh
Old Nov 2, 2008 | 01:29 PM
212nut's Avatar
212nut
i have power to both sides of the injector harnesses
Old Nov 2, 2008 | 02:26 PM
fmr9's Avatar
fmr9
How did the tank get full of water? Was the truck submerged?
You have pretty well ruled out everything except fuel, and with pressure on the fuel rail it looks like the injectors. It is possible if the thruck sat a long time the injectors are stuck, but doubful that all of them would be stuck.
Probably not getting the signal to fire the injectors. I'm not sure if this quick ground would show up on a meter, might need a scope. Someone else may know for sure.
If the truck was submerged, you could have lost the computer, or at the very least, the ground for the computer. Any wiring harness connection that got wet would also be a suspect. Bad grounds can drive ya nuts on these trucks, by causing all sorts of mysterious things to happen. I suggest cleaning the computer ground and if that doesn't help, try a different computer.
Good Luck Frank
Old Nov 2, 2008 | 02:29 PM
quicklook2's Avatar
quicklook2
in power dist. box check maxi fuse 8, it is the injector driver module.
check relay 1 and 2 in power dist box.
dist. box is under hood.
Old Nov 2, 2008 | 04:27 PM
212nut's Avatar
212nut
checked all the power to all.??????????????????????/ anyone want a great deal. going to see if when i turn it over the injector harness grounds out
Old Nov 2, 2008 | 04:28 PM
212nut's Avatar
212nut
also being there was a heavy dose of water, i will change the oil. is it possible a stuck egr valve could cuase this
Old Nov 2, 2008 | 04:41 PM
quicklook2's Avatar
quicklook2
how do you test fuel pressure?
did you just look at maxi fuse or did you change it?
Old Nov 2, 2008 | 04:56 PM
212nut's Avatar
212nut
tested fuel pressure by key on position 57psi. cranked it over 57psi. tested maxi fuse on both sides.
Old Nov 2, 2008 | 06:26 PM
212nut's Avatar
212nut
put a test light on each injector harness point, they both have continuous power when the engine is cranking. shouoldnt this go out?
