Engine & Heater temp question
Old Nov 1, 2008 | 02:31 PM
Holo20's Avatar
Holo20
Hey everyone,
I live in Fairbanks Alaska and lately the temp has been in the 0 to -10 F range when I start my 01 Expy, to warm up in the mornings before I head to work.
At that temp, the truck needs to idle for about 45 minutes before the engine (according to the gauge) is decently warm. This is not the normal temp however; once I start driving, the temp will rise to it's "normal" spot within a couple miles of driving.
When I get in the truck, it is only lukewarm inside. I know there is a lot of volume in this truck to heat up, but after 30 or 45 minutes of idling I guess i would have expected more from this 5.4.
Just wondering if you guys have any tips or suggestions or things that I might check out.
I'm no mechanic... so maybe this is to be expected with this truck, and I need to change my expectations instead?
Thanks,
-Michael
Old Nov 1, 2008 | 06:33 PM
alloro's Avatar
alloro
Stick a thermometer in the vent and record the air temperature at various stages from initial starting to driving a few miles down the road. With 0 to -10 degrees it could take considerable time to heat everything up, so knowing the air temperature at the vent will be a big help in giving you some answers.
Old Nov 1, 2008 | 11:12 PM
Holo20's Avatar
Holo20
Ok will do, thanks.
I've also been considering switching out for an electric fan, I'm thinking the engine would probably warm up faster if the radiator fan wasn't blowing cold air on it unnecessarily.
-Michael
Old Nov 2, 2008 | 12:09 PM
Slim Shady's Avatar
Slim Shady
My dad used to put a piece of cardboard over the front of the radiator during those cold Wyoming winters. It seemed to help quite a bit, as it wasnt blowing air through the fins, so it ran a bit warmer. But if you try this, keep an eye on your temp. for a while to make sure it isnt getting too hot
Old Nov 2, 2008 | 06:41 PM
Holo20's Avatar
Holo20
That is a good piece of advice, and thanks for mentioning it. Most folks around here do block off their front-ends, or maybe block off 1/2 or 3/4 of the radiator, to keep the engine and radiator from cooling down too much. Take -20 or -30 degrees and combine it with a 55mph (driving down the highway) wind, and you get quite a frosty wind-chill factor.
Thanks again for the suggestion.
-Michael
Old Nov 2, 2008 | 07:10 PM
madsonp's Avatar
madsonp
Sounds like you might have the blend door issue also. Check out this link.
HeaterTreaterweb3
Old Nov 2, 2008 | 08:32 PM
alloro's Avatar
alloro
FYI, that's a myth. There is no wind chill factor involved with cold temperatures and your vehicle's cooling system. The wind will cool it down faster, but it will never get colder than the surrounding air is.
Wind Chill
Old Nov 2, 2008 | 11:28 PM
Freak4Ford's Avatar
Freak4Ford
Possible bad thermostat (stuck open) and or bad fan clutch? How long has it been since it was last flushed out?
90pioneer
Aug 8, 2014 03:55 PM
MauleOne
Jan 11, 2013 01:25 PM
01 super
21
Apr 1, 2011 01:06 PM
Grandpa's Ford
Jun 21, 2010 12:14 PM
FairbanksDan
1983 - 2012 Ranger & B-Series
Jan 10, 2005 05:43 PM
