Sponsored by: Kumho
tars or tires????
Old Nov 16, 2002 | 07:09 PM
Ford 2002's Avatar
Ford 2002
tars or tires????
[updated:LAST EDITED ON 16-Nov-02 AT 08:20 PM (EST)]I have a F250 supercab with Goodyear 265/75/16 from factory.
They are to noisy!!!! I do not use my truck at all for off road so ride is more important. I have read post after post and it seems the BFG A/T are on the list used by this board more often than any other brand. I only see the D rating on this tire. Is there a tire with the E rating ( 10 ply ) ?
And yes I am confused about what tire I should get.
Old Nov 16, 2002 | 07:37 PM
cek181's Avatar
cek181
tars or tires????
my uncle has 285/75/16s on his 3/4 ton dodge that are 10 ply tires. i think they are made by courser. super swamper tsl's are also 10 ply but i doubt you want something that aggressive. i did a quick search for 10 ply tires and all the ones that came up were bias ply instead of radials, cept for the swampers. your local tire store should definitely be able to get you a good 10 ply radial tire.
chris
Old Nov 16, 2002 | 08:03 PM
Knobby4604X4's Avatar
Knobby4604X4
tars or tires????
If you think your stock tires are too noisy, you may not like the noise level on the BFG all terrains. Plus, if you never leave pavement, the tread may be a waste for you. My truck had as stock a set of Michelin XPS rib style tires, which last forever and are silent. They are an E range tire. Just an idea.
Old Nov 16, 2002 | 11:36 PM
deleontow's Avatar
deleontow
tars or tires????
Truck Guy99
Dec 6, 2019 09:42 AM
Green_Monster
Dec 23, 2008 01:23 PM
woody367
Aug 24, 2008 11:27 AM
fordxl68
2004 - 2008 F150
May 20, 2007 03:07 PM
bboone52
Oct 5, 2006 01:44 PM
