tires ?
Old May 20, 2007 | 01:55 PM
fordxl68's Avatar
fordxl68
tires ?
2005 screw. I have 17" tires passenger tires on my truck and I have a brand new set of 16" E rated tires I would like to put on . I need E rated for the weight I put in the back. A fifth wheel. If I get a set of 16" rims for the truck can I run the 16" tires ? any problems?
Old May 20, 2007 | 02:58 PM
Cuisinart's Avatar
Cuisinart
I don't think a 16" rim will fit over your brakes... but I could be wrong. You should measure to see how much clearance you'll need before you buy anything.
Old May 20, 2007 | 03:07 PM
WhëëlMå1's Avatar
WhëëlMå1
The minimum rim diameter on the 2004+ trucks is 17". There is no way you can run a 16.
Tiedrod
Sep 29, 2012 08:01 PM
musclecars90
Sep 30, 2010 08:25 PM
RNH Performance
56
May 1, 2010 01:24 PM
brian_06328
Feb 21, 2010 01:16 AM
stupidjet
Feb 8, 2005 10:41 AM
