I believe the airbag light is supposed to flash a code when the key is first turned on. 3 flashes then 2 = code 32, etc. Have you seen anything like that?
There are lots of lamp fault codes. Which one does your flash? Could be a sensor or loose wire somewhere. If you know which code, you'll have a better idea of where to look
I'll have to check but yes 3 flashes followed by 2 flashes is the systems way of telling you the code. 32 is the code for high resistance drivers side.
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
F350-6 where did you access the trouble shooting chart? I would like to have more info on airbag systems available.
I bought one of the service manuals before a member here posted the links on where to access them for free. They're in the tech folder sticky at the top of the forum. Be sure to leave him reps for providing the useful links.
I used to put a binder in between my seat and console, and when it rested on the long black "bar/ yube thing" on the bottom of the seat by airbag light flashes. if nothing touches it, it is fine. check those things under your seat/ seats!
