tire play?
Old Oct 31, 2008 | 02:52 PM
heathrunkles's Avatar
heathrunkles
tire play?
Started noticing a vibration on the front end in the last week and today a small clunk. Jacked the truck up and the front passenger side tire has play in it from north to south. What should I look for? Thanks
Old Oct 31, 2008 | 02:55 PM
93f1505.0L's Avatar
93f1505.0L
Check the ball joints and wheel bearings. if it is wheel bearings you will see the rotor and hub move seperate from the knuckle. if it is ball joints then you will see the knuckel move seperate from the axle.
Old Oct 31, 2008 | 04:35 PM
fordman837000's Avatar
fordman837000
best bet is to have someone stick a pipe or the jack handle under it and lift up and down while your under there watching everything to see if its moving
rattleNsmoke
Apr 9, 2013 06:26 PM
A/Ox4
Apr 3, 2013 10:29 PM
mblanken881
Feb 19, 2011 09:51 PM
dfishrmn88
2004 - 2008 F150
Oct 31, 2009 10:55 AM
03 Maz B23
1983 - 2012 Ranger & B-Series
Feb 20, 2005 04:58 AM
