Transfer case stuck in LOW
Old Oct 30, 2008 | 11:23 PM
68 ranger's Avatar
68 ranger
Question Transfer case stuck in LOW
Hi I was wondering what could cause a transfer case to get STUCK in
low gear with the hubs out. If a guy was to disconnect front driveshaft
would it be driveable? This is in a 90 F-250 6.9L I think manual tranny.
(i have not seen it yet) But the guy said it runs really well. for 600.00
would you get this??????? Manual hubs by the way.
Old Oct 31, 2008 | 12:16 AM
rupejosh's Avatar
rupejosh
for $600 heck ya the motor is worth that worse case scenario ya throw in a transfer case from a junk yard or rebuild it and away you go.that is well worth the money.people buy cell phones for more than that.i would jump on that,of course try to talk him down though haha.
Old Oct 31, 2008 | 04:15 AM
Dodge/Cummins's Avatar
Dodge/Cummins
It might be a case of operator error, I'm embarrassed to say it was in my case. The shifter says, right on the top PUSH DOWN! I didn't SEE that until someone pointed it out to my stupid @$$.
You have to push the shifter handle down to shift the x-case and it's still kind of a wrestling match.
Go look at it and give it a try. The truck will probably need to be running to do it though. Try to do it with out him seeing you or you might just run the price up. The way I look at it you've done your homework and learned how to fix it so you should reap the rewards.
That's assuming this is the problem of course.
By the way the BW 1356 in my '90 gasser shifts alot easier than the one in my '94 IDI turbo or the '97 Powerstroke. Wierd!
Old Oct 31, 2008 | 09:34 AM
Lazy K's Avatar
Lazy K
Could be as simple as the shift linkage frozen. However to answer your question, driving it would be no problem with the front shaft removed.
Old Oct 31, 2008 | 12:47 PM
joe f350's Avatar
joe f350
if ur in 4wheel low ur not go anywhere fast
Old Oct 31, 2008 | 01:40 PM
iggybob44's Avatar
iggybob44
If the hubs are unlocked you dont need to remove the front driveline, if it drives,try backing up while pushing the transfer case lever towards another position,then stop and go forward while trying this. do this slowly in both directions,shift from whatever position the transmission is in to neutral and back while moving(automatic) or try engaging/disengaging clutch.........Low range is about 2.6 or 2.7 to 1 reduction,so if you cant get it out of low,you are going to be really limited in speed.........
Old Oct 31, 2008 | 02:07 PM
joe f350's Avatar
joe f350
limted is a uder statment i was in 4low in 4 gear doing a massige paint striping tire burning 45 and 3000 rpm
Old Oct 31, 2008 | 02:32 PM
iggybob44's Avatar
iggybob44
Huhh? Im not quite sure what you are saying here,may i suggest taking a little more time proof reading before hitting the "Submit Reply" button....
Old Oct 31, 2008 | 05:34 PM
joe f350's Avatar
joe f350
i now i mean i was in 4low and in fourth gear going 45 at 3000rpm i was trying to be funny the governer on a 6.9 is 3300 hes not going any where fast i wonder if has tryed to put it in 2wd with the truck off
Old Oct 31, 2008 | 06:11 PM
iggybob44's Avatar
iggybob44
thank you Joe,i now know exactly what you meant! worth trying it shut off,try it every possible way,with a little luck he gets it working and gets a good truck at a great price....
Old Oct 31, 2008 | 06:14 PM
joe f350's Avatar
joe f350
hopfully iam right and he gets a good truck
Old Oct 31, 2008 | 06:37 PM
iggybob44's Avatar
iggybob44
At $600,its probably a good deal with a screwed up transfer case!
Old Oct 31, 2008 | 10:45 PM
joe f350's Avatar
joe f350
i paid 1700 for with lift and tires
Old Oct 31, 2008 | 10:50 PM
iggybob44's Avatar
iggybob44
id say that you got a good deal Joe!
Old Nov 1, 2008 | 02:09 PM
joe f350's Avatar
joe f350
no i had to rebuild the tranny and tcase 3700 buck and it has a d44 not a d60 be i love it any it get looks any where i go
