My 2000 powerstroke misses after sitting a few days
If I drive it everyday, no problem. every other day,it misses a little after I leave the driveway but clears up after I get on it a little. Last week, I let it sit for four days. Like to have never got it to start. Any ideas??? I am not too sharp on Diesels.
Yep. the other day, after it sat for several days, i did it numerous times. it finally started and loped till it smoothed out some. it's like the longer it sits, the less cyliners it fires on. after acceleration, you can feel it come alive. never any trouble after the inital missing.
Use a multimeter to check your glow plugs. Use the ohm reading. It should be somewhere in the range of .6-1.6 ohms. I believe thats the range anyway. But you will get the picture. None should read extremly high numbers or 0.
The wiring harness to check them is right on top of the valve cover. Take that off. The pins inside the harness go as such... GG II C II GG. G=glow plug, I= Injector, c=common ground. Test the pin to a good ground.
You will find if you havhe a bad one.
How can you tell if it is leaking down????? The other day after I almost never got it started, the longer I tried, the more cylinders that semed to fire. so, if the HPOP leaks down, the injectors don't function properly? Is there a sight window for the hpop???Seems like in my memory there is.
