Need Glowplug help
Old Oct 31, 2008 | 10:50 AM
PaysonPSD's Avatar
PaysonPSD
While you have the valve covers off re-torque the rocker arm pedastals and the injector hold downs. Those who have done this have found quite a few loose bolts.
Injector Hold-Down Bolts......120 in/lbs = 10 ft/lbs
Rocker Arms Pedastals............ 20 ft./lbs
This is a tip I read and am glad I did.
Once the glow plug is broken loose slip a tight fitting piece of tubing over the end to thread it out. Use the same method to thread new ones in.
Old Oct 31, 2008 | 11:07 AM
lawngrease's Avatar
lawngrease
great suggestion of checking and also using the tube. I have never done this before, but it looks like it is going to be a pain in the butt to do this. Anything that helps will be a welcome change.
Old Oct 31, 2008 | 11:14 AM
schlepprock250's Avatar
schlepprock250
Nah...its a pretty straight forward job. Just be sure to soak up all the oil around the glow plug holes so as to not get oil seepage in there,also, definately use a piece of tubing to remove the glow plugs(the socket gets stuck if you dont),but its not that bad of a job.
Schlepprock
Old Oct 31, 2008 | 11:16 AM
PaysonPSD's Avatar
PaysonPSD
Not a difficult job, just time consuming. There are 3 VC bolts on the passenger side I found easier to get to through the wheel well using a box end wrench. But at that time I didn't have wobble extensions.
Old Oct 31, 2008 | 01:01 PM
shacks87's Avatar
shacks87
Thanks for posting this, I had checked mine with AE and it said they were good, but this cold snap has proven diffrent. I ohmed mine and found the front & back on both sides are bad. Thanks for all the good info.
Old Oct 31, 2008 | 07:02 PM
lawngrease's Avatar
lawngrease
I have bought the tube and glowplugs (Motorcraft zd-11's $18.99 @ O'reily's), which are much more expensive now, and have already cleared the way for the driver side. How do you get to the rear bolt loose? It is darn near impossible to get to.
Old Oct 31, 2008 | 07:49 PM
PaysonPSD's Avatar
PaysonPSD
I believe I used a 1/4" ratchet, short extension and a deep socket.
Old Oct 31, 2008 | 08:53 PM
maevans's Avatar
maevans
Chris, I had to cut some of the aluminum covered fire protection off of the firewall to get to the back bolts, reinstalled it with some aluminum foil tape.
It gave me just enough room. Good Luck.
Old Oct 31, 2008 | 09:47 PM
megawatt00's Avatar
megawatt00
Chris and I ahve been going back and forth with PM's on his glow plugs. Thanks for all the additional input from everyone. I also suggested he change his GPR whereas he had many GP's that were not working. This way the whole system is "new"
Old Nov 1, 2008 | 07:14 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Dont go to the dealer to get plugs.. I had to go there to get one, as the tip was bent up against the head deck surface from the failure and i couldn't get it out-- $27.99! (for one!)
Old Nov 1, 2008 | 10:14 AM
schlepprock250
I used a short wobble extension for the hard to reach bolts.
Old Nov 2, 2008 | 07:56 AM
danskool's Avatar
danskool
Go Bills !
WOW, Why would AE say good and actual be "bad"
$19 For one GP !... I have 3 dead ones. I was thinking replace them all, But i guess not. I thought they were cheap until now. Were is the best place to get them?
ahnjoan
Jul 17, 2013 02:46 PM
Breaker 1-9
Apr 13, 2012 03:38 AM
mmustafa
Feb 27, 2008 08:30 AM
dstrech
Modular V10 (6.8l)
Jul 23, 2003 04:05 AM
mrblue01
Aug 7, 2001 03:10 PM
