White Smoke
Old Oct 30, 2008 | 07:36 PM
Blankie's Avatar
Blankie
White Smoke
I am getting a lot of White Smoke at start up, and truck does not seem to have the power it should. 96 F350 185000 miles. Any ideas.
Thanks
Jim
Old Oct 30, 2008 | 07:55 PM
custom_nirvana's Avatar
custom_nirvana
how cold is it? colder it gets more white smoke and longer it takes to warm up and i know with mine if its cold it feels powerless. could be glow plugs try cycling wait to start light a few times before u start or plug'er in and see if that helps.
Old Oct 30, 2008 | 08:20 PM
maverick1701's Avatar
maverick1701
X2! if I dont let mine cycle (usually 2mins) before starting after a cold night I have some white smoke and it feels sluggish until the engine gets at least a little warm
Old Oct 30, 2008 | 08:24 PM
JethroF250's Avatar
JethroF250
Just turn the key on and let them sit a while. they cycle for i thin 100 and some secs. If that doesnt help then most likely injector orings. I know my truck needs them bad. 188000 and never touched them. each year the smoke gets worse. Just my 2 cents. But if cycling gps dont work then my money is on orings
Old Oct 31, 2008 | 12:04 AM
c00nhunterjoe's Avatar
c00nhunterjoe
max gp on-time is 120 seconds. you dont have to cycle the key just because the wait lamp goes out.... watch the volt gauge. and white smoke on a cold diesel is normal as is sluggish throttle on any heui injector system when the oil is cold and thick.
Old Nov 9, 2008 | 01:36 PM
Blankie's Avatar
Blankie
I think after all of the info it may be time for O Rings. I just don't look foward to the job. Thanks for info.
Jim
Old Nov 9, 2008 | 09:16 PM
c00nhunterjoe
how does it run after the engine warms up?
Old Nov 10, 2008 | 08:01 AM
Blankie's Avatar
Blankie
It runs OK but still seems to be low on power comparing to other power Strokes I have had. When pulling RV it falls on it,s face at the least little hill. The only mod on the truck that I know of is a Superchip. I do have a 3" down pipe I am going to install when time permits.
