guy's i have and 86 ford bronco that the body is toasted on can i put a f150 reg cab shortbox on the bronco frame its got all the good stuff under it a 9'' rearend 4speed manual trans and a 351w so i would like to keep it thanks for the help
The rear cab mounts on a pickup are inside the frame, on a BKO, they are on the outside, not a big deal, just need to change out a crossmember. But, the bed is another story, you need to cut a foot out of the front of it to make it fit on there. I have seen it done, and if done properly, it doen't look half bad.
All the good stuff will bolt in under the pickup if you keep the pickup frame.
