Hope not a big problem....
Old Oct 30, 2008 | 07:50 AM
Capt.Schenk's Avatar
Capt.Schenk
I'm not sure if the cooler weather has anything to do with this problem or not. Tuesday and Wednesday mornings I let my truck idle for about a minute in the driveway and then head-off through the neighborhood towards the Interstate. When coming to a stop in the neighborhood and idling, my RPM's dropped to 500 and and the truck feels and sounds like it's about to stall. Thursday morning (today) I was in 2nd gear at 2000 RPM's, pushed-in the clutch when approaching a stop sign and it stalled. I started cranking for 3-4 seconds at a time, but it wouldn't start. Finally, on about my 5th try, it fired-up, but this time I had my foot on the pedal. I let it drop close to idle, but it felt like it may stall again, so I got moving and didn't stop again until the truck was fully warm. Once it was warm, I had no more idling problems.
I was thinking fuel pump or fuel filter, but didn't know if the cooler weather would cause this. Any ideas?
Old Oct 30, 2008 | 07:56 AM
F350-6's Avatar
F350-6
Is your CEL on? How's your oil level? Fuel issues typically show up at higher rpm's, but it's always a good idea to check your filter.
Old Oct 30, 2008 | 09:34 AM
Capt.Schenk
CEL is not on. Oil and oil level are good.
Old Oct 30, 2008 | 01:05 PM
tinker934's Avatar
tinker934
glow plugs, fuel heater???? and or plug the truck in at night??
Old Oct 30, 2008 | 05:44 PM
F350-6's Avatar
F350-6
Sounds like you've got a sensor not reading right somewhere. I'd say the best thing to do at this point is to get the truck on a scanner that reads live data. See if there are any biased sensor readings. I'd pay particular attention to ICP pressure compared to IPR %. (when the engine is cold and acting up)
tiqman1
1983 - 2012 Ranger & B-Series
May 4, 2013 08:48 AM
4601ton
41
Sep 13, 2012 04:31 PM
Mark DeDo
1997 - 2003 F150
Feb 3, 2012 12:15 PM
NeoCowboy
16
Mar 26, 2010 02:56 PM
michaelbrainardatwor
Nov 10, 2009 01:34 PM
