Bronco Tire Size HELP
Old Oct 29, 2008 | 08:31 PM
mlgodwinone's Avatar
mlgodwinone
Exclamation Bronco Tire Size HELP
Guys I need some help. I need to find out if 33x11.50 AT's will fit my 1992 Full Size Bronco without any mods to my suspension. I bought coil spring boosters to put in my coil springs but i have heard bad things about them so I would like to know if i can fit my 33's without the boosters. If anyone has done this or knows any info that can help please let me know.
Thanks for your time.
SCFIREFIGHTER
Old Oct 29, 2008 | 09:35 PM
ChancesDad's Avatar
ChancesDad
Not sure about the 92 Bronco but I ran 33's on my '78 F-150 with stock ride, I have ran the Coil Spring lift bolts and I crushed them first time out on the trails.
'97 F-250 HD XLT SuperCab 4x4 O/R 460 - 5 Spd
'96 34ft Fleetwood Bounder 460 - E4OD
'68 F-100 Custom Cab on '78 F-150 Ranger 4x4 Frame 390 FE - C6
Old Oct 29, 2008 | 11:13 PM
Fox_Racing's Avatar
Fox_Racing
You will probably fill the fenders all the way up if they fit, my dad had 25/75/15 on his 93 bronco and they fit great. I think they are the same as a 31 ish so you should have enough room as long as your front end isnt worn out.
Old Oct 29, 2008 | 11:21 PM
9.ford.5's Avatar
9.ford.5
33's fit fine in a 96 f150 SC SB they might do a bit off rubbin if you try and bottom er out but other than that the fit fine without the leveler
Old Oct 30, 2008 | 12:10 PM
sp metalman's Avatar
sp metalman
We have 33/12's on a 94 at our deer camp and they fit fine on the stock suspension rub alittle when turned full tilt L & R
Old Oct 30, 2008 | 12:16 PM
preppypyro's Avatar
preppypyro
Ive had 33's on my old 89 1/2 ton 4x4, no rubbing no suspension mods, they fit nice. 10 inch wide rims, tires were kumho something or another.
Old Oct 30, 2008 | 09:02 PM
mlgodwinone
Thumbs up Thanks
Thanks guys for all y'all s help. I will be showing pics after i get my tires on whether there 33s or 32s. I look forward to hear y'all s comments. Take a look at my gallery to see my truck now. Search for a 92 Bronco I posted it 10-10-2008.
SCFirefighter
Old Oct 31, 2008 | 03:18 AM
TexasGuy001's Avatar
TexasGuy001
I would just put 32x11.50 tires on it.
