no I dont believe so when it comes to memory i know 351w/302/300 are all going to have the same bellhousing and the 351m/400/460 have a larger bell housing
Look for the Ford rear axle ID tag, it was originally under one of the bolts that attaches the carrier (pumpkin) to the housing (usually around 5 o'clock).
When you post the info from that tag, I can look up what axle was used with that specific rear end. Will then post the spline count.
No tag? Not surprising, they're usually missing by now.
Post the AXLE code, found on the second line of the Warranty Plate...located on the left door face below the latch.
thanks, are there diffrent types of bolt pattern the c-6 trans other than BB and SB?
You have the 385 series BBF 429/460 also 351M/400 use one pattern, then the small block including the 351 Cleveland and 300 I6 uses one pattern, then you also have the FE's 352 thru 428 that use their own pattern, and the C6 was put behind all three Hope that helps
