02 E250 COP question
Old Oct 29, 2008 | 06:37 PM
puntadigital's Avatar
puntadigital
Hi there
1st post here
I have an 02 E250 5.4 V8 bought it couple of months ago, 161K, and I have used it less than 500 miles so far.
CEL came on, and the codes showed missfire on Cyl 1 and 5 and something about low power on the first 1000 revs (sorry I don't remember).
Checked spark plug on cyl5 and it looked a little black (carbon) but not a whole lot and switched COP with cyl 6 to isolate problem. Erased codes and took it for a ride and CEL came on again showing the same, PLUS another code that says something like "random cylinder missfire".
my plan:
Change all spark plugs and COPS. Found a cheap one on ebay and basically that's my question, if it's worth buy them and change 'em all, or just buy the Motorcraft or Duralast and change just those 2.
Here's the link to eBay
Thanks in advance
Carlos
PS: CEL flashed several times, in different moments, specially when you step on the gas trying to make the van recover some power, based on what I've read in here that means something related to CAT right? why not codes about it ?
Old Oct 29, 2008 | 09:08 PM
puntadigital
Anxiety bump !
Old Oct 31, 2008 | 08:06 AM
Clubwagon's Avatar
Clubwagon
Yeah, sounds like the COPs are getting weak. That "random cylinder missfire" code is typically the first you see. Then the individual cylinder missfire codes start.
Sounds like a good plan. Can't say if the ebay COPs are OK or not. I always worry when I see something that is "too cheap". I would price the COPs from RockAuto.com. You can count on those being of acceptable quality.
Old Oct 31, 2008 | 05:12 PM
puntadigital
Thanks ClubWagon
I think the same about things when they're "too good to be true", but this things at least have a 1 year warranty, and I can get the 8 for the same cost of buying only 2 (Duralast) at autozone, I'll check Rockauto and see their prices.
Would you guys recommend getting just the 2 that are failing or take the risk with the cheap ones? I cannot afford 8 of the "good" ones right now, probably get the 8 cheapos and when things get better I can replace all of them with quality ones.
What kinds of risks am I taking doing this?
Thanks for the help y'all
Old Nov 1, 2008 | 11:39 PM
davistev's Avatar
davistev
Smile
I am in the same situation but I decided to only change COP #4 on my 5.4L E250. However, I did use the opportunity to replace all the spark plugs. I ended up using Autolite Double Plats because I my local Autozone was sold out on the Motorcrafts.
Old Nov 2, 2008 | 10:41 PM
puntadigital
Hey, how was it ? How long ? you still have all your knuckles ?
Old Nov 4, 2008 | 04:23 AM
davistev's Avatar
davistev
Changing the spark plugs on the 5.4L is a job I hate to do but I am not rich enough to pay a garage $3-400 to do it. My E-250 was difficult but made easier once I
1) removed the passenger seat
2) used a rubber hose (from the power steering unit) to retrieve the spark plugs that "sat" inside. The most difficult one to do was #7.
Cheers,
Dave
Old Nov 6, 2008 | 01:16 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 6, 2008 | 01:17 PM
PerfDistIgnition
FTE Sponsor
Please see them at:
__________________
FTE Sponsor
butch h
Escape & Escape Hybrid
Nov 7, 2016 11:38 PM
V10truck
Modular V10 (6.8l)
Jul 31, 2015 08:35 PM
Klau
1997 - 2003 F150
Dec 7, 2013 02:45 PM
tuvluv82toy
2004 - 2008 F150
Dec 6, 2011 07:50 AM
marsh brothers
Mar 23, 2011 02:32 PM
