Sponsored by: Kumho
Michelin tires
Old Nov 28, 2002 | 09:40 AM
Ford 2002's Avatar
Ford 2002
Michelin tires
[updated:LAST EDITED ON 28-Nov-02 AT 10:41 AM (EST)]Had 265/75/16 mounted on my F250 4x4 and just got back from a 1500 mile trip. I will say the ride was great. The tires are out of balance at one speed ( 75/80 ) but anything below 75 or above 80 rides real smooth. I wonder if the tires can be rebalanced to get that perfect ride. I was told that the 10 ply was hard to balance
and that I should be happy with this setup.
I did notice that there are a lot of weights on the wheels.
Old Nov 28, 2002 | 12:01 PM
superrangerman2002's Avatar
superrangerman2002
Michelin tires
yes,
Some times on larger tires they need to be run a good bit before they will break in. If there is a lot of weights on now, a rebalance after the trip that you just took should bring some of those weights off.
About the 10 plys being tough to balance is BS, it's probably more like that they didn't want to balance them right.
when you talk about alot of weights, are they all on one side of the rim (looking at the tire laying down on the ground) or are there weights on 2 different areas of the rim?
Old Nov 28, 2002 | 02:14 PM
Ford 2002's Avatar
Ford 2002
Michelin tires
There are about 10 or 12 weights on the four wheels.
Most measure about 3" or 4" long, they are inside and outside on each wheel.
Old Nov 29, 2002 | 09:00 AM
superrangerman2002
Michelin tires
[updated:LAST EDITED ON 29-Nov-02 AT 10:00 AM (EST)]>There are about 10 or 12 weights on the four wheels.
hmm sounds about right, I'd still take them back to have them rebalanced, In most cases a rebalance after 2000 miles will knock some of that weight off.
Hope that helps some.
good luck!
Old Nov 29, 2002 | 09:14 AM
steve83's Avatar
steve83
Michelin tires
Mikel_NY
2009 - 2014 F150
Oct 17, 2017 06:49 AM
Truck815
Feb 22, 2016 09:43 PM
Michael Roark
Jun 27, 2015 11:16 AM
Capt.Schenk
Aug 16, 2014 08:07 PM
Mikec35
Jan 6, 2014 10:30 PM
