Sponsored by: Real Truck
Tires Rubbing
Old Oct 29, 2008 | 06:13 PM
Jeff02250's Avatar
Jeff02250
Tires Rubbing
I have an 02 F250 Diesel. I had the truck leveled couple of years ago when I bought a set of 35/12.5x18 with American Eagle Rims. I’ve been living with the rubbing on the leaf springs since I bought them. Now I have bought new set of the same size of rims and tires off of Craigslist, but the rims are a bit more reversed. I bought these just for the tires but the rims are so nice I would like to put them on the truck. The problem is that they rub when I crank the wheels left or right. They are rubbing on the wheel well shroud on the rear of the wheel well. Can that shroud be cut with out causing any problems down the road? The wheels clear the front bumper just fine. Also lifting the truck is not an option, I use the truck for work and it’s already hard enough to work out of already.
Thanks
