Sponsored by: Real Truck
Engine Vibrations
Old Oct 28, 2008 | 08:15 AM
zachbing's Avatar
zachbing
Engine Vibrations
Hi,
I have a 2004 5.4 F250. I have vibrations coming from the engine at 50mph at around 1200rpms while it seems like the truck is in 5th gear. Only vibrats when i excelerate slowly as soon as i let off the gas or the tranny shifts down all vibrations gone. I have a lift kit on the truck but it would vibrate the same before the lift went on. Any help or hints would be great! Thanks
Zachbing
Old Oct 28, 2008 | 08:21 AM
senix's Avatar
senix
have you checked all you motor mounts to see if any are broken.
Old Oct 28, 2008 | 08:51 AM
stumpbuster's Avatar
stumpbuster
gee wiz i would hate to hear you had a broken motor mount B4 you put the lift on w/ a '04!!!
but yea, senix is right.
did you change yer tires since you put the lift on?
my guess is its prolly not so much the engine as it may be a front end issue or a misweighted offbalanced tire/ allignment issue.
Old Oct 28, 2008 | 10:24 AM
zachbing's Avatar
zachbing
Like i said it was vibrating the same way with the stock 265's and it does the same thing with the new 35's. I tires came mounted and balanced and i had the wheel alligned after i put the lift on. What kind of trouble and money are we talking if it is the motor mounts and how do i check and inspect?
Thanks for the help guys!
Old Oct 28, 2008 | 10:31 AM
senix's Avatar
senix
Try from below and from the engine compartment. Engine mounts to the frame, a visual inspection is a start. You then can start the truck with it in park rev up the motor from under the hood and see if the motor is moving excessively, that can help to pin-point that issue as maybe a cause.
Old Oct 28, 2008 | 10:48 AM
enduro4231's Avatar
enduro4231
Hey all, thought I'd contribute.
I have a 2002 F250 5.4L and it has I believe the same problem. When I am cruising at ~1500 RPM the engine/trans seem to shake and the truck won't accelerate unless I push the pedal enough to get the trans to kick down a gear. If I try to accelerate from that ~1500 RPM spot the truck will not, it just shakes. Now, it only does this in gear, not neutral and it doesn't matter how fast I am going.
Maybe this is the same problem as the OP.
Could it be a torque converter problem? Doesn't seem like a broken engine mount would limit acceleration.
Old Oct 28, 2008 | 12:57 PM
zachbing's Avatar
zachbing
I am not seeing anything wrong with the mounts what is this about the torque converter?
Thanks Zach
Old Oct 29, 2008 | 09:51 AM
enduro4231's Avatar
enduro4231
I'm not sure, but for me, I really only get the vibrations/shaking when the truck is in 4th gear (I belive) because it does not do it if overdrive is off.
Old Oct 29, 2008 | 10:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds more like a misfire ...
Old Oct 29, 2008 | 10:33 AM
RckyMntnKng's Avatar
RckyMntnKng
I was going to guess the driveline is out of balance or carrier bearing shimmed wrong for the lift, but it was doing it as stock....so I would guess the motor mounts next.
Old Oct 29, 2008 | 10:41 AM
senix's Avatar
senix
yes my thoughts were the carrier bearing as well, but didn't go there as it was a issue stock as well.
Old Oct 29, 2008 | 10:44 AM
Heavy_Metal's Avatar
Heavy_Metal
I'm thinking a misfire also. Seen it too many times.
Old Oct 29, 2008 | 07:30 PM
enduro4231's Avatar
enduro4231
then why does it not occur when revving the engine in neutral? or does it have to do with the engine being under a load?
Old Oct 29, 2008 | 08:47 PM
krewat's Avatar
krewat
Under a load, the spark needs to be much stronger to ignite the charge. If the spark is weak, it won't ignite a very dense (under load) charge.
Could be a wet hole
Old Oct 29, 2008 | 09:29 PM
enduro4231's Avatar
enduro4231
Ok. I don't have alot of experience with anything other than carburated engines, but isn't there an individual ignition coil for each cylinder? I know my father's 1999 E250 with a 5.4L uses this. A friend also recommended I look into the knock sensor?
