DP TUNER just the regular f-5 swtich that can be mounted to the dash by velcrow. Best to order you some gauges for her first and get the gauge pod controller or the F-5 holder that mounts around the gauge.
I really dont want to do gauges. I dont tow excessive amounts and dont run her hard. If I were to do gauges I would go for something that was one of those electronic all in one types of deals as opposed to 3 individual gauges. Any recommendations on an electronic all in one gauge type of deal?
I would not run a DP Tuner without having at least an exhaust temp gauge whether towing or not. I can hit 1200+° in no time with stock injectors. And if you don't have an upgraded free flow exhaust you are looking for a meltdown if you don't monitor the EGTs.
Gauges would be a whole lot cheaper than a new block...
What does a new block have anything to do with running a chip on a medium performance tune without towing heavy or doing something to the equivalent of a salt flat top-speed run?
I need to learn from you, What should the exhaust temp be and what is to hot? EGTs mean what????? Bare with me please.
Exhaust Gas Temperature. The temperature in which the exhaust is leaving the cylinder head. 1250 degrees is the maximum you want to hit for short bursts otherwise piston melting can/will occur.
Im just saying that without knowing what the temps are exactly you wont know when to back off. I ran my chip without gauges for a little while and I know how surprised I was the first time I saw how fast that red needle moved..
