It wouldn`t take long to fill your truck up Sheldon, there`s tons of standing dead fall poplar bluffs here the right size for firewood with no splitting needed.
I`ll keep that in mind Sherm, it`s a dream of mine to extend the shop about 20/24 X 30 ft.
The main point when adding on would be to make it fairly energy efficient to keep the heating costs down. It would be only around 1,600 sq ft. so not too overly huge to heat.
2 story is what you need Fom...not overly hard to do, eliminates the need for costly concrete work, and you don't have to totally heat all the space. a couple of small vents in the floor between the 2 levels will provide sufficient airflow and keep the frost away, while the bottom level where your work is being done is toasty and efficient.
with a floor truss joist system, 12" OC and doubled 3/4 inch sheathing, it'd be plenty strong enough. i should figure out some time how that would compare to a ground level construction with concrete...
I think what little heat I would want afford would quickly disappear up stairs........
