The peice you are showing in your photo is the "charcoal canister purge solenoid". One line goes to the canister, the other splits into a "Y" and goes to the top of your throttle body. This purges fuel vapor from the canister.
My inquiry is about the the unit on the injector fuel rail. I want to know what would be the symptoms if this was not working.
Thanks guys. I have no codes at all. What I do have is a 4.9 in an E250, 3 speed auto, that drinks gas like I get it for free. Head,crank, lifters, pushrods, oil pump, Egr valve, O2 sensor, about 13k ago, new cap, rotor, distributor, wires, plugs, thermostat, temp sensor, Msd coil, all within the last 3 months. Timing is @12 degrees. I'm just reachin' here...bought "new" injectors off of Ebay when I replaced the head. I'm starting to wonder if they may be the wrong "poundage". Truck has always been dependable, but eats to the tune of 10 - 11 mpg, has no power at top end, tops out at 70 mph.
