Mounting Stacks
Old Oct 27, 2008 | 09:39 AM
kaotikedge_111100's Avatar
kaotikedge_111100
Mounting Stacks
How is everyone mounting their stacks? Any pictures of underneath the bed area?
I have two 3" stacks that i used to have mounted in my bed before the body swap. Now with the nice new bed and 3" exhaust I have fabbed up off the ATS downpipe I want to get some ideas before I start in.
Old Oct 27, 2008 | 01:49 PM
kaotikedge_111100
Any idea where I can get 3" flex pipe? I think I am going to just do a single 3" on the passenger side.
Old Oct 27, 2008 | 02:24 PM
kaotikedge_111100
These are the pipes I am working with:
tires are 39" for reference
I am thinking of just making the 3" hole in the bed and running some bolts through the flange on the stack and make a backing plate for it on the underside. Then welding a 3" 90* to the bottom of the stack and connecting to my current exhaust with something flexible to allow the truck to flex like it should.
Thoughts?
Old Oct 27, 2008 | 03:33 PM
F250FarmBoy's Avatar
F250FarmBoy
Try summit racing for the flex pipe.
Old Oct 27, 2008 | 05:42 PM
ghunt's Avatar
ghunt
Old Oct 27, 2008 | 05:52 PM
kaotikedge_111100
That is a nice looking setup you have there! Did you build that from scratch or did you buy a kit? The ATS downpipe is 3" did you flare it up one size after that?
Old Oct 28, 2008 | 03:28 AM
LCAM-01XA's Avatar
LCAM-01XA
This is what your truck will look like in that case:
Looks decent on a dually, kinda brings the big-rig look to it, but on a SRW 4x4 I dunno... Those stacks you got sure look nice tho
Old Oct 28, 2008 | 03:38 PM
ghunt's Avatar
ghunt
Yeah, I did everything from scratch. I built the splitter pipe myself (out of a few 4" mandrel bends and some straight pipe).
I stepped it up to 4" at the end of the downpipe. Originally had it going clear out the back, but just put the stacks on about a week ago.
Old Oct 28, 2008 | 09:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You made your Tee the hard way.
The vertical cut can continue down to the bottom inlet which is how I made mine.
I guess not having two welds at the bottom let you use clamps to connect the elbow though, mine is welded.
Old Oct 29, 2008 | 08:40 AM
ghunt's Avatar
ghunt
That's why I did it that way
Glad I did too because I had a lot less vertical room than I had expected (notice the under bed pic).
Really wasn't hard to do either. Just a little measuring, a little cutting, a little fitting...and then welded it up.
Old Oct 29, 2008 | 08:23 PM
bigblackF250's Avatar
bigblackF250
ghunt, where did you find your stacks? I know you made the splitter and tubes just curious about the chrome ones..
Old Oct 30, 2008 | 10:21 AM
ghunt's Avatar
ghunt
I bought the stacks from airflo.com.
They were originall $100 each, I got them for about $92 each because I tried to buy some they had listed on special and they were out, so they gave me a bit of a discount.
Shop around, you might find a better deal on ebay.
