Hydralic Clutch Problem
Old Oct 27, 2008 | 09:18 AM
57Junior's Avatar
57Junior
I have a 96 Big Bronco with an M5OD. I recently went to use the clutch and the pedal went to the floor with no resistance. I checked and the master cylinder was out of fluid. I refilled the resivoir and tried to bleed the system with my hand vacuum bleeder and got little to no fluid through it. The pedal still goes to the floor. I replaced the master cylinder about a year ago because the plasitic eyelet on the pushrod broke. Is there an easy way to rule out the slave cylinder without having to drop the trans/case? Is there a better way to bleed the system?
Thanks in advance.
Old Oct 27, 2008 | 03:27 PM
84-250's Avatar
84-250
With the loss of fluid, I would remove the bellhousing inspection cover and see if the slave cylinder is leaking fluid.
turp
Aug 20, 2013 09:35 AM
rmalottwtes30
Apr 30, 2010 11:47 AM
JICASE
25
Jul 29, 2008 06:03 AM
redbug
Nov 25, 2003 07:29 PM
Shay
Oct 31, 2002 04:46 PM
