death shake
Old Oct 27, 2008 | 03:56 AM
nickyhatch's Avatar
nickyhatch
death shake
hey i have an 89 f250 fwd....
i have a seriouse death shake at around 40 mph...i ifgured it was the ball joints.. however i replced those.. and still shake is still thier.. what else do u think it could be...oh and threw new inner and outer bearings in as well
Old Oct 27, 2008 | 06:43 AM
Camo93XLT's Avatar
Camo93XLT
Are your wheels out of balance? Mine had stick on weights on the back of the rims and one side came off. Up to about 45mph it was fine then it felt like the frontend was coming off. Had them rebalanced and the problem was gone.
Old Oct 27, 2008 | 07:48 AM
Lazy K's Avatar
Lazy K
Also check the front spring and shackle bushings. Others have reported that fitting a steering damper solved the problem.
Old Oct 27, 2008 | 12:12 PM
phoneman91's Avatar
phoneman91
If the tie rod ends are new--be sure to get an alignment. Incorrect toe can cause this also. Either incorrect toe in or out.
Incorrect toe caused this big time on my Jeep Grand Cherokee for years. The toe in was adjusted correctly and it now doesnt have this problem.
Old Oct 27, 2008 | 02:34 PM
crazyredneck's Avatar
crazyredneck
how old are your tires? well, age does not matter. i used to work for a construction company and we drove an early 90's f250 that would just randomly do the death wobbly. i finally talked them into replacing the tires. give that a shot and see what happens.
make sure you replace all four tires.
Old Oct 27, 2008 | 04:06 PM
paintslinga2010's Avatar
paintslinga2010
mine did the same thing with bad u joints. Only at certain speeds though, really weird, shook at 45 on the dot, nothing faster or slower.
Old Oct 27, 2008 | 06:14 PM
Opossum's Avatar
Opossum
Mine had the same problem always at 35mph. I needed tires, and an alignment that fixed the problem.
If this "death shake" shakes the stearing wheel it is in the front end, either tires or alignment or both.
Two things I recommend;
Check the alignment too much toe can cause this, run your hand across the top of the tire, if there is to much toe in the tire will be featherd and grab your hand more on the edges of the tread while pulling from inside to out.
DYNABEADS ROCK! I need no balancing weights on my 37" swampers, a notoriously hard tire to balance this stiff truck with big mud tires rides like glass on the highway check them out.
Old Oct 27, 2008 | 11:53 PM
nickyhatch's Avatar
nickyhatch
thanks alot guys for a quick reply... im gonna balace tires so if that helps
