Electrical short in lighting system Need help
What is the significance of the hot pole where the loose wires attach?
Might those be wires that feed only the running and tail lights?
How do I access the breaker to tighten the connection?
As for that last question I notice a few bolts holding a plate to the engine compartment side of the fire wall. Might that be an access to the back of the dashboard?
Any help for this electirically challenged novice will be greatly appreciated.
Usually the hot pole is related to poor electrical flow - a poor connection or bad ground somewhere in your system. I have a theory about your problem but I'll get back to it.
The best way to access the breaker to check the wires is to drop out the gauge package. They are mounted on it. Your power for your running and parking lights is supplied from the same wire and attaches to the headlight switch where my drawign below has the pink box that says "hot bus" on the left side. (the other hot bus connection powers the running lights and headlights when the switch is pulled out to the next detent). A loose connection on th ebreaker or the switch will definately cause flickering and high heat.
As far as wiring is concerned, the running (tail) lights and Parking (front small) lights are both run on wires and posts on the headlight switch that are different than the headlights. Here is a diagram of the switch if properly wired:
I had the same problem with the light flickering that you have and it was cause by three things: First I had an inadequate ground out in my front clip because I have a full front tilt hood - grounding stap from hood to frame salved that. Second my wiring was a mess with lots of loose connections both at the screw down posts and in the connectors - rewired, but if you just tighten up the screws, recrimp the connectors and tighten the plugs that's ok.
But lastly, it sounds to me like your headlight switch contacts colud be loose inside the switch if tightening th ewire connections doesn't solve the problem. There is a square copper plate inside there that slides withthe **** when you pull it. It slides onto and contacts small metal **** on the bottom of the rabs your wires are screwed onto. If the plate gets hot, it warps and makes the contact worse. Also, the headlight switch bakelite piece the wire mounting tabs are cast into melts and the tabs come loose - also negating a firm contact withthe slide inside the switch.
So, here is what I would do: 1) take out the instrument cluster and check all the wires and connections on the breakers for the lights; if that doesn't do it: 2) remove the headlight switch and check that. Look for firm connections and make sure none of the mounting posts can't move or are corroded. Test the switch function with a meter to make sure it isn't intermettently making contact inside (causing the flickering). I might have a replacement switch available. 3) make sure all of your lights have good grounds. But if the front and back running and parking lights all flicker together, it's the headlight switch or the wire connections on the switch or at the breaker.
Feell free to send me a PM if you need help troubleshooting - or with anything for that matter.
J!
Eric
Good luck, it sounds like a bad connection to me
Bobby
What I know in life comes from bad experience....mine, if not someone else's.
I do really appreciate the assistance you all give! What a great resource.
Eric
Eric
Julie
PS to get the cluster out (52 right?) there are two studs welded to the dash top and bottom. The cluster has two tabs that mount on those and then a nut goers on top. Not hard to undo but your wiring will probably make it tough. I'd leave it alone unless absolutely necessary.
In this picture it is on it's side! Turn it clockwise 90*
Here's the back. And I think it's upside down (yes, the gauge with just the loop on it is the AMP gauge and it goers to the upper right when installed). There are two square things under the paper where it is marked "H" and "A." Those are your circuit breakers (you can see the hook ups for them), and they go on the left as you are sitting looking at the gauges. You can see the mounting tabs here too.
Julie
When my turn signals are on , my volt gauges flickers down along with it. If i put the brake lights on, it almost goes to almost 0 . Engine off or going down the road same thing. Also when i turn my lights on, my LED highbeam light stays on all the time. Hit hi beam id does get brighter, but low beam it stays on.
Trying to find proper grounding strap spots so i can verify all that. I have read Neg direct from battery direct to engine to as close to starter as possible, from that same ground point, run another ground to frame, from taht same point to body and to firewall. Not sure about my bed could not find anything on that.
Any ideas would be appreciated, i would rather over ground than under ground. Also what TYPE of ground wire to use. Neg battery 4ga, 12g etc?
Thank you
Len
I noticed you asked the same question on another thread - guessing the answers weren't enough to solve your challenge.
