Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Steering Stabilizer Failure
Old Oct 26, 2008 | 07:41 PM
Bouts21's Avatar
Bouts21
Went to the local Parts Source today and picked up a new steering stabilizer for the Crew Cab. Checked it out before installing and it was the same size, diameter as the one on the truck, so I changed it over. Went for a quick ride around the block afterwards and found that it was squirting out fluid. Now questions are, did I install it incorrectly? Or is it faulty? When I installed it it looked like it was at a slight upward angle to the side that moves with the steering. On the Crew Cab, one end is mounted to the shock mount, and the other to the long tie rod. If it is angled slightly it shouldn't make a difference as it is rubber mounted and should move some. Any opinions?
Old Oct 26, 2008 | 08:10 PM
Corner Gas's Avatar
Corner Gas
I'm no expert but it sounds like a failure to me. A slight angle like that should not cause any problems that I can think of.
Old Oct 27, 2008 | 12:23 PM
preppypyro's Avatar
preppypyro
I would take it back, I doubt it was installed that incorrectly.
A/Ox4
Jul 5, 2014 06:30 PM
smoky_diesel
6.7L Power Stroke Diesel
34
May 27, 2014 11:47 PM
cajun_driller
Mar 16, 2014 07:30 PM
lg3rd
Sep 1, 2005 07:47 AM
danike
Offroad & 4x4
Jan 14, 2003 06:44 PM
