Transmission Removal
Old Aug 20, 2009 | 11:38 PM
JefflovesF250s's Avatar
JefflovesF250s
Any suggestions on transmission removal from a '66F250? I have cab off and engine is removed. Want to take tranny out to clean and repaint frame. Do remove drive shaft at rear of tranny and lift it out say with an engine hoist or is it better to drop it down with a floor jack?
Any hints/advice much appreciated. Jeff
Old Aug 21, 2009 | 04:52 AM
jowilker's Avatar
jowilker
Jeff, Which looks easier to you? It shouldn't matter. You will need to borrow a slip yoke as the tranny will leak heavily when the drive shaft is pulled. Or you can ****** it quickly and keep it tail high to stop or prevent leaking. Be prepared if you have a finished floor.
John
