hmmm, the things that come to mind are dirty filters, heavy right foot, bad fuel, ebpv malfunctioning, clogged ebpv sensor tube, or a really heavily loaded truck. What gears?
We need WAY more info to help you out.
When was the air filter last changed? What air intake are you running (stock, aftermarket?)
When was the fuel filter last changed?
Tire size?
Gear ratio?
Stick or auto?
Any go-fast mods- tuner, big injectors, different turbo?
Are you getting good fuel?
Do you run bio?
Lots of things factor in to fuel mileage. Probably one of the biggest is that diesel likes to foam when you fill up, so often you don't get the tank truly full because there is a "head" of foam at the top of the tank, so when you calculate MPG you are way off. Also, never rely on the stock computer if you have one, they are well known for being inaccurate.
i have a k&N intake, dp tuner, all filters changed 200 miles ago, 6in lift with 37/13.5r17 tires, auto trans, stock injectors, stock gear ratio, stock turbo with a banks upgrade wheel.
I would ditch the K&N right away...don't want to kill your turbo. The additional rotational mass from the larger tires would hurt mpg, but not halve it... Has your mileage just recently dropped or has it been low for a while? Maybe your torque converter isn't locking...regearing may help too
Agreed ditch the K&N and see if you can get the truck recalibrated. The lift and big tires will murder your MPG even more so if you have a heavy right foot. Check your turbo boots and such for leaks and also check for exhaust leaks around your up pipes both are MPG Killers.
