Hard start-not normal symptoms
Old Oct 25, 2008 | 09:10 PM
ferret2's Avatar
ferret2
2000 Excursion with GPCM (California). It takes about 3-4 seconds of cranking before it fires. No CEL. No white smoke when finally starts. Same long crank above or below 55 degrees (I think that's the point glowplugs come into play). No sputtering or romp after it fires and no loss of power. Batteries are good as is alternator (new). THe HPOP oil level is normal. It starts quicker when warmed up. My previous GPR truck would fire within the first second.
Thanks
Craig
Old Oct 25, 2008 | 09:50 PM
O2BNMUDD's Avatar
O2BNMUDD
I have a 2000 superduty same problem hard start after sitting over night. Long crank drawing down on batteries .I have gone through the hpop check the batteries load tested they are new.Checked cables .I t start good after the truck warms up I can start it hard and then turn it off 30 sec later and it starts fine. Well after some more diagnostics I did I removed the starter took it to a rebuild place I know they split it open and it was all corroded and bad in side .He said this is comon in these trucks because the water leaks down into them. I ordered a new high torque one from db electric e-bay 123.00 plus 25.00 shipping it will be here on tues . I am very sure this is the problem but I will know for sure tuesday.Good luck hope this helps
Old Oct 26, 2008 | 04:19 PM
ferret2's Avatar
ferret2
Thanks for the advice. The engine comes up to speed right away during cranking, above the 100 rpm minimum, so I'm going to keep looking.
bigbassman43
Oct 8, 2009 08:05 PM
Campbell 56
Oct 30, 2007 08:11 PM
jwith68
Aug 24, 2006 08:25 AM
supercab blue
Dec 27, 2004 07:56 PM
blitzkraig56
Sep 26, 2002 01:02 AM
