Tranny rattling my bones
I just got back from the big North/South F-100 Run in Santa Maria CA, and on the drive back up to the Bay Area I started hearing a rattling coming from the front transmission area. It's a C4 attached to a 79 302, and the rattling occurs in all gears, only above 2000 RPM. It doesn't make any noise during acceleration or deceleration, just when maintaining a steady speed. Has anyone encountered this problem before? Thanks
Craig Early
Craig Early
Craig, check your u joints, if they look ok then have your drive line checked out it may have gotten a little bend in it or maybe a weight fell off, the drive line has to be balanced or you'll have a vibration, if that checkes out ok then you may have lost a weight on the fly wheel.
Ok so this string is a little old but as I was tearing my truck down for its complete tranformation I went to remove the speedo sensor from the tranny and ATF came gushing out. That's not supposed to happen as far as I know. So with the aforementioned symptoms and this new finding does anybody have any new ideas? Thanks
Craig
Craig
DavefromSB
04-27-2013 11:29 AM
genscripter
04-14-2013 07:06 PM
