66 floor pan coating
Old Oct 25, 2008 | 09:07 PM
bliss1's Avatar
bliss1
i was thinking of putting a bed liner on the floor of cab to prevent it rusting in the future. is this the best thing out there for this or is there something else.
next ? what is the best thing for coating the under side if the floor pan.
Old Oct 26, 2008 | 06:32 AM
jowilker's Avatar
jowilker
One of my long term goals is to coat the inside of a cab that I have from the top of the windshield all the way around to under the dash with a spray on bedliner. This should provide insulation and sound deadening that would be hard to get any other way. You can also put it under the cab floor instead of inside for added protection. my 2
John
Old Oct 26, 2008 | 09:34 AM
daveengelson's Avatar
daveengelson
Eastwood has some insulation panels may want to take a look at. Applied coat or two of rust prevent paint, believe 'rust bullet', or 'por's15'. Took the jute backed alum. padding, sprayed floor pan with 3M adhesive spray and set the padding down, small areas at a time to get the padding to mold to the contour of the pan. Then used alum tape secured the perimeter and any seams. The carpet was installed other that, this was few yrs. ago and holding up grate. Certainly cut down on road noise and to certain extend insulation. Also, insulated the doors and used a product that comes in 12"X12" sheets and it's crap, subsequently, took it out. Intend redoing doors using another product, it added noise reduction and insulation while it lasted.
Old Oct 27, 2008 | 12:38 PM
bertha66's Avatar
bertha66
When I put the spray in bed liner, I had the inside of the top of the cab done. It does work good as a sound deadner and for rust. I did the floor with a Hammerrite paint and the under side with a self spray on under coating.
Old Oct 27, 2008 | 12:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You can buy a bedliner coating product that's similar to Rhino Lining in one gallon cans from AutoZone, then you can either spray it, or brush it on.
Be careful buying any insulating panels, some of them retain moisture.
The stuff used by Ford in the 1960's above the headliner as sound deadening material and inside the doors did exactly that.
Ford also used a sound deadening material inside the doors that was nothing more than undercoating.
The undercoating began to peel off, water got between the undercoating and the doors, y'all can guess what happened next.
rwrogers
Jan 21, 2014 12:53 PM
RangerHaywood
May 25, 2010 09:03 PM
highoctane74
40
Dec 31, 2009 11:05 PM
Sgt Wonderful
Paint & Bodywork
Nov 10, 2007 07:18 AM
truckman15
Jul 31, 2007 12:40 AM
