plow compatibility 78-93
Old Oct 25, 2008 | 05:50 PM
copracer288's Avatar
copracer288
I have a 78 F150 Camper Special that has a plow.
I may be replacing that truck with a 93 F250 XLT.
Will the plow frame and everything else mount up to the 93?
Any other info on the 93 I should be aware of?
Thanks.
Rob
Old Oct 25, 2008 | 07:35 PM
T.McG's Avatar
T.McG
I just went through this with my '77 to '94 F250s. I was going to try using the '77 mount and adapt it to the '94 but it was going to envolve a lot of fabricating. My plow is a Western 8' pro plow with the uni-mount system. After talking to the dealer, I decided to buy the bracket kit that mounts to the truck frame and get the ultra-mount adapter that allows you to hook a uni-mount to the ultra-mount bracket. The part that the plow pins to comes off with the plow so there is more ground clearance in the front when the plow is off. If in the future, you get an ultra-mount plow, you will already have the hook up on your truck. The frame brackets and adapter cost ~ $650 but well worth it in my opinion. Saved me a lot of time trying trying to make the other one work. Also, I think my truck will set high enough that I won't need the extra plow lights.
Old Oct 25, 2008 | 08:11 PM
95F350XL's Avatar
95F350XL
Frame is same between 87-96(97-98 F250/F350) I have a Meyers 8" on my F350 and I dont have to use the plow lights, I have 36's on stock suspension and its too high lol. Even up the truck lights are over the plow.
Old Oct 25, 2008 | 10:07 PM
copracer288
Thanks for the replies guys.
Not the news I was hoping to hear. I'll definitely have to take a close look at it. Hopefully it can be made to work without too much expense.
The 93 is, by no means, a sure thing yet and this is certainly a consideration.
Rob
Sgt93
6.7L Power Stroke Diesel
20
Apr 27, 2020 07:51 PM
papajerry
21
Jan 5, 2017 08:08 AM
19-F250-78
May 8, 2016 08:02 PM
VT tree grower
May 8, 2016 04:32 PM
78f3504x4
General Automotive Discussion
Mar 2, 2005 12:22 PM
