for numberdummy
Old Oct 25, 2008 | 03:27 PM
77 ford shortbed's Avatar
77 ford shortbed
Smile for numberdummy
yes sir my name is joe an I am installing factory integrial ac in my truck. have the dash everything even got a factory commpressor bracket from a salvage yard for my 302 v8. yes I think youre right about a bigger radiator though have the template for the firewall also. ducts ductwork vac lines condensor everything was taped up when I got it for moisture. the thing is the the wire harness is what I need for the factory ac. yes Im the guy with the wiring questions. centech is a company that makes wire harnesses but they are not ford factory colors for a 1977 ford truck. If I could find a good used one I could start installing this. do you have the right # radiator I may need thanks for your help. joe
Old Oct 25, 2008 | 04:07 PM
80F100man's Avatar
80F100man
very true, as it is no one else but the 2 of U know what this 1 is about .....maybe someone would have had the radiator you're talking about lying around in good shape....
Old Oct 25, 2008 | 05:40 PM
77 ford shortbed
sorry for the triple posts
