Sponsored by: Real Truck
power window noise
Old Oct 25, 2008 | 01:10 PM
RIDE RED's Avatar
RIDE RED
power window noise
I have a 05 crew cab.My drivers window makes lots of noise going up until it gets 1/2 way then its quiet.Is my window regulator going bad? Or does it just need lubed? How much will it cost to fix?
Old Oct 26, 2008 | 12:23 AM
motometal04F350's Avatar
motometal04F350
i have the same problem on the pass front door. it sounds almost like a grinding noise starting about a third of the way up, then it just grinds pretty much until its shut...
Old Oct 27, 2008 | 01:08 PM
RIDE RED's Avatar
RIDE RED
Anyone else have a noisey window?
Old Oct 31, 2008 | 04:02 AM
hawaiiv6's Avatar
hawaiiv6
mine makes noise too. Has for a year, hasn;t gotten any worse, just annoying.
Old Nov 11, 2008 | 11:51 PM
RIDE RED's Avatar
RIDE RED
noise getting worse.Any help?
Old Nov 12, 2008 | 03:24 AM
f2504x408's Avatar
f2504x408
Window Noise
Mine does it, sounds like a rachet clicking, passenger side is doing it also,started after a year old.
Old Nov 12, 2008 | 02:52 PM
RIDE RED's Avatar
RIDE RED
WHATS THE FIX!!!!!!!!!!
Old Nov 12, 2008 | 03:45 PM
ReAX's Avatar
ReAX
I have a scratching noise. My plan to solve it (today or tomorrow) is to wet a rag with a silicone based cleaner/detailer and wipe the tracks down.
If you want to pull the door panel, white lithium grease is good for the pivot points.
Old Nov 12, 2008 | 04:42 PM
SuperDutyScaler's Avatar
SuperDutyScaler
guys i have a 04 F-350 and my dad has a 00 F-350 they were both making the same noise as you guys. i simply took off the door panel and lubed the track, it looked like it never was done by the factory. I also sprayed the window track with silicon spray and now the windows go up and down like their on nitrous and absolutley no noise or shutter.
Old Nov 13, 2008 | 12:50 PM
johnf350diesel's Avatar
johnf350diesel
mines noisey too
Old Nov 13, 2008 | 11:32 PM
RIDE RED's Avatar
RIDE RED
bump.bump.
Old Dec 19, 2008 | 12:21 PM
Euclid's Avatar
Euclid
Mine are noisy, too.
Sounds like some silicon lube on the tracks fixes this problem, based on what SuperDutyScaler said.
I'll pick up some lube today and try this - I'll report back here with my findings.
Old Jan 3, 2009 | 08:37 PM
jamie7375's Avatar
jamie7375
lube the tracks on the inside of the panel and silicone fixed mine..nice and quiet and alot faster..
Old Jan 3, 2009 | 11:05 PM
Bowie's Avatar
Bowie
on mine I fixed the inside of the panel as well. there are like 2 rain or water guards. it was the inside guard that was pinching the window.
Old Jan 3, 2009 | 11:06 PM
Bowie's Avatar
Bowie
I used silicone and also pried it back. It some how was bent in.
