Carb Help Quick
Old Oct 24, 2008 | 11:16 PM
kjmdrumz3's Avatar
kjmdrumz3
Carb Help Quick
Took the carb off to rebuild it. On the pass side of the carb there is a small canister type thing with with the word "Lean" on it and arrows pointing in a clockwise direction. There is a metal tube leading from the canister to the manifold. What is that for? Because it broke off at the manifold. Please help! Thanks
Old Oct 24, 2008 | 11:18 PM
brentleedragon's Avatar
brentleedragon
i could be wrong and please correct me if I am, but I think you're talking about your adjuster for if the truck is running lean or rich and is relatively important
Old Oct 24, 2008 | 11:25 PM
kjmdrumz3's Avatar
kjmdrumz3
There is little hash marks and a black plastic cover that you can turn 2 or 3 marks in either direction. What happens if it's not connected? Basically I'm asking if it will A) catch fire or B) run.
Old Oct 24, 2008 | 11:26 PM
masterbeavis's Avatar
masterbeavis
its the choke heat tube. If you broke it, dont worry. Just plug the vacuum port on the carb so you dont create a vacuum leak. You can convert it to an electric choke, or just turn that black cover to lean so the choke does not stay on forever. Yes it will run, no it wont catch fire.
Old Oct 24, 2008 | 11:28 PM
kjmdrumz3's Avatar
kjmdrumz3
Thank you very much for the quick response! Much appreciated guys.
Old Oct 24, 2008 | 11:29 PM
kjmdrumz3's Avatar
kjmdrumz3
Also, which screws do I adjust for the idle? Cold and warm? Where are they? I have a Haynes manual but it doesn't show a picture.
Old Oct 24, 2008 | 11:33 PM
masterbeavis
they are on the front of the carb, right below the float bowl. Start off at 1 1/2 turns. Hook up a vacuum gauge, aim for the highest vacuum readings. Quickly whiff the exhaust, tune till it dont stink rich. Be careful, you can die from carbon monoxide poisoning. There are other (proper) ways to adjust a carb, but this way works easy enough for me, and gets it close enough. Also, adjust your timing, and adjust the idle to keep it where it otta be.
Old Oct 24, 2008 | 11:35 PM
kjmdrumz3's Avatar
kjmdrumz3
1 and a half turns from completely in or completely out? Don't have a vacuum gauge, so should I listen for best idle and smell the exhaust? Also, which one is for fast idle and which one is for warm idle?
Old Oct 25, 2008 | 12:27 AM
fmc400's Avatar
fmc400
MSEE
The tube running to the choke is the hot-air stove. Without it, your choke cannot open. You need this hooked up for the stock choke to function correctly. Or, you need to close it up and install an all-electric choke like masterbeavis suggested.
masterbeavis's procedure for setting idle mixture is good; I use a vacuum gauge myself. Curb idle is on the driver side of the carburetor. Fast idle is a separate mechanism and is on the passenger side. Here is my writeup on setting fast idle, it will tell you everything you need to know. Ignore the first couple paragraphs about the float.
https://www.ford-trucks.com/forums/7...ml#post6422219
By the way masterbeavis, long time no see!
Old Oct 25, 2008 | 12:45 AM
kjmdrumz3's Avatar
kjmdrumz3
Need a picture of where the springs attach to. I'm almost done! Help
Old Oct 25, 2008 | 12:54 AM
fmc400's Avatar
fmc400
MSEE
Which springs are you talking about?
Old Oct 25, 2008 | 01:16 AM
kjmdrumz3's Avatar
kjmdrumz3
The ones on the drivers side of the carb. Trying to figure out where they attach to.. some pics of the carb would be helpful!
Old Oct 25, 2008 | 01:20 AM
fmc400's Avatar
fmc400
MSEE
This is the only shot I have. The only spring on that side is the throttle return spring. You can somewhat see it in this picture. I'm assuming you're working with a stock 2-barrel carb?
Old Oct 25, 2008 | 01:23 AM
kjmdrumz3's Avatar
kjmdrumz3
Yes, but I also have a larger spring that came off of that side. Which is holding the throttle closed. Basically, when I open the throttle everything works fine, but it doesn't shut.
Old Oct 25, 2008 | 01:30 AM
fmc400's Avatar
fmc400
MSEE
That would be the throttle return spring. It's responsible for bringing the throttle back to closed after you pull back on it. I looked through some photos of an engine pull I did and found one that might help some more. Here it is:
As you can see, the throttle return spring connects between a bracket mounted to the throttle body, and the throttle linkage itself. I can't say I've ever seen an additional spring used here. There may be a second spring mounted to the transmission kickdown linkage, but I don't recall seeing one before.
