Injector line seals?
Old Oct 24, 2008 | 08:27 PM
scottm1's Avatar
scottm1
Well, I found my oil leak today....it was the flat gasket of the high pressure oil pump. I changed the gasket, installed new o-ring kit, and got it all back togeter just to find I have a injector line leaking now at the fuel filter housing. The rubber seal/packing tore during disassembly and I did not realize it until it started leaking after trying to restart the truck. The problem is that it was after 5 when I realized I needed the seal, and the dealership was closed. So then I started calling the parts store that stay open after 5 like Auto Zone, Oreilly's, Advanced, and none of them have them, nor do they even have a listing for them. Does anybody know where to get these other than the dealer on a weekend? Are these a dealer item only? Is it possible a implement dealer may have them? Any help would be appreciated.
Old Oct 24, 2008 | 08:51 PM
F350-6's Avatar
F350-6
Can you give a little better description of which line is leaking? On the fuel bowl assembly, you've got a fuel supply line (coming in), fuel return line through the FPR (fuel pressure regulator, fuel feed lines (one to each head) and a water drain valve. Any idea which one is leaking?
Old Oct 24, 2008 | 08:54 PM
zx250's Avatar
zx250
Of the next Riffraff East
You can go to lowes, home depot or any hardware store and get what they got in the right size. Will need to change again when you get the Viton o ring but anything will get you going again.
Here's an O ring chart for you.
7.3L PowerStroke O'rings
Old Oct 24, 2008 | 09:06 PM
scottm1's Avatar
scottm1
It is the metal injector line on the rear of the right side of the fuel filter housing that is leaking. It is the steel line that attaches to the fuel bowl, then goes underneath to the drivers side front injector. The rubber sleeve is torn in that fitting where the nut tightens down to the line flare alowing the leak. It is not an o-ring, but the rubber sleeve. Is that also available at a Lowes or Home Depot to get me by until Monday until I can get to the dealer?
Old Oct 24, 2008 | 09:28 PM
rbaker6336's Avatar
rbaker6336
those are vibra-loc seals 1/4 or 5/16
Old Oct 24, 2008 | 09:53 PM
scottm1's Avatar
scottm1
Are the vibra loc seals available anywhere except the dealer or some place I have to wait for them? Does the chain part stores carry them?
Old Oct 24, 2008 | 10:03 PM
zx250's Avatar
zx250
Might have a little more trouble finding an alternate replacement for those. The parts numbers are listed on the oring chart if that helps.
Old Oct 24, 2008 | 10:11 PM
mueckster's Avatar
mueckster
You might be able to use a small section of hose as a temporary replacement. We've had to to that at work before.
Old Oct 24, 2008 | 10:37 PM
scottm1's Avatar
scottm1
thanks mueckster....that is a good idea. That is the kind of help I was looking for. I hadn't thought of that. It only has to last until Monday morning
Old Oct 25, 2008 | 07:00 AM
just another truck's Avatar
just another truck
O rings work as well, I stacked 5 of them on the tube, sorry, it was a emergency fix that has still held up, I used Viton,
