Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2001 lightning compression reading
Old Oct 24, 2008 | 06:33 PM
dova's Avatar
dova
Anyone know how much compression it should have cylander 1 is 120 and #2 is 80 has a tick you can hear in the exhausts low power i had a sparkplug burn up in #2 need help thanx.....
Old Oct 25, 2008 | 06:03 AM
ckirwan514's Avatar
ckirwan514
sounds like a cracked piston. if you burned a plug you are running to lean and need to check your tune.
Old Oct 25, 2008 | 02:37 PM
FTE Ken's Avatar
FTE Ken
80 psi.... crap that's bad. Pistons should be within 5% of each other in a healthy engine. Could be many things... burnt or damaged valve, bad score on the piston wall, broken piston ring... none of them good.
Does sound like too lean, or the tune was written properly for the weather as it cools off (depends on where you live, its not cold here in Georgia yet) and it's adding way too much timing (Roush was/is doing this with some of their 2004+ F150 tunes).
IsoGrifo
Oct 16, 2009 06:37 PM
Ranger1F150
31
Apr 9, 2007 01:31 PM
kaharshbarger
1983 - 2012 Ranger & B-Series
Oct 29, 2004 09:18 PM
Schoonie48F2
Flathead V8 & Flathead 6
Nov 30, 2003 10:17 PM
tealboy1
Apr 28, 2002 03:18 PM
