stupid question
Old Oct 24, 2008 | 09:19 AM
rebel1803's Avatar
rebel1803
stupid question
I have always heard that there is a ratio difference between 6 and 8 cylinder drive axles, how much of a difference is there between a 6 cylinder and V8 gear ratio for a 1979 f150 4X4?
I have a 79 f150 4X4 w/300, the rear pinion is shot. I have a 79 f150 4X4 w/360 and i was wondering if i can swap the front and rear pumpkins into my 6 cyl. unit or would the v8 ratio be too much of a jump. also since i am really lazy(I dont mind crawling around on the ground but it is always easier when you know what ur looking for) could anyone tell me how to locate the axle code locations for the front and rear axles and how to identify the gear ratios if the ratio tags have been removed. Since i know i dont know much any help would be greatly appreciated.
Old Oct 24, 2008 | 10:12 AM
ranger429's Avatar
ranger429
I don't know where you heard about the different gear ratios from a 6 to V8 but they were wrong.
The standard ratio for a 4x4 F-150 in 79 was 3.50, it doesn't matter if it was the 6 cylinder motor, the 351M motor or the 400.
The only other gear choice that was an option for the 6 cylinder was the 4.11.
Optional gear choices for the 351M/400 were the 3.00 or a 4.11.
In 79 they did not use a 360. The only engine choices were the 6 cylinder, a 351M or a 400. Mind you this is for 4x4 only as that is what you posted. They did use the 460 motor in 4x2.
The front D44 should have a tag on the diff cover. It would be located on the passenger side of the cover in the center retained by two bolts. If there is no tag you can jack up the truck and turn the tire while watching the # of times the driveshaft turns. 3 1/2 turns would be a 3.50, 4 turns would be a 4.11.
Oh and instead of calling the thread "stupid question", "help me", etc... put the actual problem in the title. It makes it easier to come up in the search feature in the future. This thread title would of made more sense labeled "axle question".
Old Oct 24, 2008 | 01:14 PM
rebel1803's Avatar
rebel1803
Thumbs up thank you, Im impressed.
God I hate computers, anyway I was hoping the "stupid question" would grab someones attention. You are right axle question makes much more sense. My only defense is that I am new to the forum and havent completely figured out how to use the site. It took me almost an hour to figure out how to start a new post... I know your scratching your head right now but I have never been the sharpest shovel in the shed, a post hole digger would better describe me as I am always digging holes I have trouble getting out of. LOL. Anyway your post was very helpful and I truely appreciate you helping me not only with the "stupid question" but with good informative solutions for my post. This is very cool. Matter of fact I am going to turn a few of my ford buddies onto this site, I think they might find the site very helpful also. lol I love these emoticons.
Old Oct 24, 2008 | 01:25 PM
ranger429's Avatar
ranger429
That's why I didn't flame ya to hard. Welcome to FTE.
Old Oct 24, 2008 | 01:51 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The only thing I can think of that he might of heard is that the rear end ratio "recomendations" for max fuel economy, and/or towing differs between engines.
However the ratios are all interchangeable, as long as they match front axle to back axle.
Old Oct 24, 2008 | 02:21 PM
4x4 Bart's Avatar
4x4 Bart
For the front axle it would be easier to swap the whole axle rather than swap the "pumpkin". The rear axle its a toss up.
I wonder how large of tires your running and what ratio you have now.
