(I'm kinda hoping for the 5-star tuning guy to chime in. )
So I'm driving my Excursion today and I got to thinking... (dangerous)
GM has recently made the injector shut-off strategy more "aggressive" on their new trucks. I notice mine shut off when coasting down steepish hills or if I've been coasting awhile. But there is no real set pattern that I can discern yet. BTW, my Scan Gauge II will display 9999 in the MPG field when they shut off.
Do you think this parameter can be changed to make it a bit more aggressive and do you think it would yield any positive results?
What would be the downside?
That can be done,and it will be beneficial over the long term. There are many small tweaks that can be done for economy,but several of those tweaks affect driveability and smoothness. If you can deal with some lost smoothness,then you can save a slight bit in fuel cost over the long term. The biggest problem with manipulating every last parameter(esp the injector shutoff),is that every vehicle responds slightly different to those adjustments,and it's almost a custom tune situation with many hours spent getting it just right.
JL
That’s an excellent thought nothing dangerous about it. Johnny is correct those Coasting Fuel cut off parameters can be changed to be more aggressive but go too aggressive and you loose some smoothness when off/on go pedal.
When modifying on those parameters its best to make small changes to see how vehicle performs.
Some of the things that effect when coasting fuel cut off is activated and deactivated are:
MPH
Load
RPM
Close Throttle
Coolant Temp
I read an article that tested one of SCTs "Economy" canned tunes on an F-150. It said the a/f ratio was leaned out on low throttle or off throttle situations. The truck picked up like .2 or .3 mpg.
On a V10 truck there are only minimal gains in economy. But there are HUGE gains in power/driveability improvement with no loss of economy with a proper tune.
JL
Injector shutdown and startup is fairly seamless however it can be felt. If you have a scangauge you can easily see when the injectors are shutoff and when they are on when monitoring mpg.
I now have confirmed that a good tune can help. We took a 750 mile run around western MT over the weekend. Averaged 2.5 mpg on the trip. Ranged from 12.1 bucking a wind to 13 on a tank that probably only saw 70 mph a couple times but included quite a bit of stop and go stuff.
With stock tune the windy run would have been in high 10s or low 11s. 13 mpg was just a dream. Never happened. The 5 to 10% increase is a nice bonus. Will pay for the tuner in about one year. Best part is still the performance.
