hesitation
Old Oct 23, 2008 | 08:34 PM
fords all the way's Avatar
fords all the way
hesitation
i ahve a 94 inline six and i can barely press the gas and it kinda wants to die for a split second has ne one had this problem
Old Oct 24, 2008 | 08:12 AM
6CylBill's Avatar
6CylBill
Mine has been doing this for a long time. It's so subtle I don't even notice it when I drive normal. If I put my truck in Park or Neutral and barely touch the gas pedal, it acts like it's going to die before revving up. Maybe it's a 300 habbit? Doesn't seem like it's any kind of a real problem. Just a 300 fart.
Old Oct 24, 2008 | 09:40 AM
Harte3's Avatar
Harte3
Sounds like something nearly "normal" in the last of the carbed models too.
Old Oct 24, 2008 | 02:09 PM
6CylBill's Avatar
6CylBill
Harte, maybe it's an I6 thing. I was waiting at a red light with a Big Rig next to me. The light turned green and I could hear the Big Rig clearly; it sounded like it did the exact same thing mine will do if you barely touch the gas pedal. The big rig didn't apear sick in any way.
Old Oct 24, 2008 | 02:35 PM
fords all the way
yea thats exactly what it sounds like well thanks atleast im not the only one
Old Oct 24, 2008 | 04:55 PM
fmc400's Avatar
fmc400
MSEE
No Ford production engine is "supposed to" do that. My 300 accelerated perfectly when I had the Carter 1 barrel, and still does now that I put the Edelbrock 4 barrel on. I wouldn't think an EFI should do that since EFI is supposed to be an upgrade. This is a sign of a lean condition. When is the last time you tuned it up? How many miles on the injectors?
Old Oct 24, 2008 | 05:58 PM
6CylBill's Avatar
6CylBill
My 300 accelerates perfectly and I bet the author's 300 does, too. It's something that only happens when you just ever so barely tap the gas pedal in park or neutral. I don't doubt a fresh 300 is not supposed to do this but it's nothing serious.
Old Oct 24, 2008 | 06:45 PM
fmc400's Avatar
fmc400
MSEE
If this is the case then I haven't noticed. On a carbed engine, sometimes you can hear the engine shudder for a split second if you gun it in park. This is due to the float compensating for the sudden demand in fuel by opening the needle valve. Not sure what would do this on an EFI. I haven't experienced this just while feathering it in park, though.
Old Oct 24, 2008 | 07:27 PM
6CylBill's Avatar
6CylBill
If you try this, please let me know what it does for you.
Off tipic, but when I feather in park and stop, the motor will continue to feather itself ever so slightly. Why is this?
Old Oct 24, 2008 | 09:58 PM
Harte3's Avatar
Harte3
If it were carbed I would guess that maybe only a very slight movement of the throttle is not enough to activate the acc pump but I wouldn't have a clue on the EFI. I haven't noticed this happening with my daily driver...straight six ISX 565 Cummins.
Old Oct 27, 2008 | 08:50 AM
corpsedub's Avatar
corpsedub
unplug the green EGR vacum line and see if it jerks then. you'll get a check engine light but no jerk. if that's the case, you have the classic 300 EGR issue.
Old Oct 27, 2008 | 03:49 PM
Paul T's Avatar
Paul T
I agree, my 88 F150 300-6 did that and it used to drive me up the wall. No one else noticed it but I did. I changed the EGR out and no more hesitation.
Old Oct 28, 2008 | 07:40 PM
fords all the way
yea i probably need to check that but lik he said its so subtle
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
Ford_Six
Nov 13, 2002 08:45 PM
