Please tell me this is normal...
Old Oct 23, 2008 | 08:32 PM
superduty4x4's Avatar
superduty4x4
Monkeying around under my truck tonight and I notice this:
I know the pics aren't the best, but what you see is a non-continuous spot in the frame rail, right above the sway bar link mount. If it's not supposed to be this way I'm NOT going to be a happy camper.
Old Oct 23, 2008 | 08:42 PM
big poppa's Avatar
big poppa
Is that a Rivet thats down in that round hole, like it got pulled in??
Old Oct 23, 2008 | 08:47 PM
empiretc's Avatar
empiretc
it doesn't look like that anywhere on mine. are those welds?
Old Oct 23, 2008 | 08:48 PM
jdecker88's Avatar
jdecker88
I know the front section of the frame is welded and bolted together incase it needs to be replaced that though looks rough but you can see the weld in the top it looks like
Old Oct 23, 2008 | 08:56 PM
Ponyboychris's Avatar
Ponyboychris
Hard to tell from your pics but mine looks very similar.
Old Oct 23, 2008 | 09:09 PM
superduty4x4
The rivets are all where they are supposed to be, I was just concerned when I noticed that it appeared that the frame had been cut and spliced back together with rivets and welds, but apparently it's the norm so I'm good.
Old Oct 23, 2008 | 09:15 PM
jdecker88's Avatar
jdecker88
Chase quit looking at your truck your going to have a nevous break down.
Old Oct 23, 2008 | 09:18 PM
whitetr's Avatar
whitetr
It is perfectly normal... Mine looks identical and all the other trucks I have seen have that same spot.
Old Oct 23, 2008 | 09:23 PM
bdrummonds's Avatar
bdrummonds
Yep, its a boxed butt joint. there is a tubular piece inside that the two ends are riveted to.
Old Oct 23, 2008 | 10:48 PM
Ponyboychris
Without the extra length to the front end, we would have cabover trucks...
OK, I'm going to bed now.
Old Oct 23, 2008 | 11:18 PM
big poppa's Avatar
big poppa
You can rest now Chase, Brandons here.
