Isspro Performax Data logging...
Data logger plugs in where one of your gauges are or you can add a new T somewhere in the cab... Plug it in to a USB port on your lap top and every gauge you have connected to the ESP is getting recorded...
I was going to get a video of the software running, but the camera was dead. Here is a screen shot.
I have a few suggestions for tweaks to the software...
1. Add a graph option, something similar to the AE graph
2. Make the indvidual screens larger for each info box
3. Allow you to pick which ones you want to look at or save rather then have all them.
4. Ajustable data streaming, I dont see why I need to know what the pyro is doing every tenth of a second.
I'll charge the camera and get a quick video tomarrow. There is also a software mistake, showing manifold pressure as pyro2 and vice versa.
Yes, you can data log for anything that is hooked to the ESP under the hood, I have my HPOP T unhooked so you are not getting a reading there. And I didnt have the Boost 2 gauge in earlier today.
A few shots on how the data logging connects. Once in production there will be a differant connection, but no matter what it will be in the cab and in line where ever you want.
