temp sensor (overhead display)
Old Oct 23, 2008 | 05:37 PM
indebt's Avatar
indebt
can some one tell me where this bugger is, mine is stuck at -40 and I think its missing. I am going to order a new one ( thanks ED ) I want to know where she goes. TIA
Old Oct 23, 2008 | 05:43 PM
PaysonPSD's Avatar
PaysonPSD
Look below your Zoodad. It should be in that area.
Old Oct 23, 2008 | 05:56 PM
indebt's Avatar
indebt
how dare you!
Old Oct 23, 2008 | 06:01 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
Mounts in the rad support(grill) area.
12A647
Ed
Old Oct 23, 2008 | 06:25 PM
indebt's Avatar
indebt
ok I cant find anything must be missing.
on this of the engine
I found this plug on the lower right side. Is that it?
Old Oct 23, 2008 | 06:35 PM
indebt's Avatar
indebt
also in this area
I found this?
Old Oct 23, 2008 | 06:37 PM
FTE/PARTS-GUY
Former Vendor
I think so, I stop stocking it cause it was a slow mover so I can't go look at one. but it looks right. See if there is any ID numbers on the part.
ed
Old Oct 23, 2008 | 06:39 PM
F350-6's Avatar
F350-6
Since it's got to see outside air temps, try looking through the grill from the front side of the truck Jorge.
Editang I'm slow tonight. Posted this before you put up the pictures of the front.
Double edit: Can I redeem my slow typing abilities with some pictures? Robin is correct about looking under your zoodad. You'll have to look behind that grill of yours. No idea what the wires you showed go to.
Old Oct 23, 2008 | 06:43 PM
indebt's Avatar
indebt
well that first plug is a "dummy" it has nothing when I unplug it can someone check and see if that is where thiers is?
Old Oct 23, 2008 | 06:46 PM
indebt's Avatar
indebt
Hey, Chris, I tried and I dont see anything...that jumps out at me anyway. I'm pretty sure the thing is gone so its hard to "see" what I am missing (if that makes sense). I finally fixed my overhead display since I bought over 2yrs ago and now no temps.
EDIT: I'm off to take my son to practice so I will check back with ideas you guys have in about 1hr....thanks!
Old Oct 23, 2008 | 07:34 PM
F350-6's Avatar
F350-6
I posted pictures of the one from my wife's truck. Scroll back up to see them. My post had been the last post for a little bit, so I thought I could just add the pictures before the thread moved on. I guess I should have known better.
Old Oct 23, 2008 | 08:20 PM
indebt's Avatar
indebt
Thanks Chris, Looks like the pics in post #6 are what I need. By the looks of yours my wires have been cut and those spade ends were put on. I will have to see what the probe looks like when I get it to mod up a connection. I am on rep lock down so I will get you when I can.
