Leveling Coils On Bronco?!?!
On my 94 bronco, i have an ever so slighty sagging front end. On my stock rims, 15x7, i would like to put on a set of 33x12.50 or 32x11.50 BF a/t's. IN order to fit them, will i NEED the coils?
Chances are the 32's will be the ones i buy. How much rubbing should i expect, and Will i absolutely need a 10inch rim to have them on my truck?
Who makes a nice leveling coil if i decide to do this, and about how much am i looking at?
>NEED the coils?
You can fit 32's stock, but only on a minimum of 7.5" wide rim on an 11.5" wide tire. If you get a 33, you'll need the leveling coils and they will be crammed in there so I wouldn't suggest it without a good lift. Leveling coils are typically 1.5" of front lift and no rear lift. For 33's you will need an 8" minimum or wider. You will see people who have run a 7" wheel on an 11.5" wide tire or even a 12.5" wide tire, but using the recommened manufacturer width will provide better handling and longer tire wear on the street. IMO 1/2" below the recommended width is ok but an inch or more is to much. I run 32's on the 7.5" eddie bauer wheels. I think if you had an 8" wheel it would be perfect whether you choose the 32's or lift and 33's. I myself don't think it's safe to use a 7 or 7.5" inch wheel on a 12.5" tire, people have done it but I think it's unsafe. If you don't want to buy new wheels, your other option is a 33/10.5" tire, that will fit fine on the stock wheels. But if I were you I'd take off a wheel and look at the back. The size is stamped and I've heard conflicting stories whether they are 7 or 7.5" wheels. If it's a 7", you'll need new wheels if you get the 32s or 33s unless you get the 33/10.5's. 32's will rub, and 33's will be even worse. They rub on the radius arm when the wheel is turned. The only way to avoid it is to have a wheel with the correct backspacing. My stock Eddie Bauer wheels rub on my 32s but it's not to bothersome to me, as it only rubs at full turn so I just don't turn the wheel all the way. The 33/12.5s will be a lot worse.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds
.Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Superlift makes some decent leveling coils, but you might just consider new OEM coils if yours are sagging. Superlift also sells some spacers which go under your coil to give up to something like 1" lift. I dont' recall the details, call Superlift.
