priming fuel lines
Old Oct 22, 2008 | 05:17 PM
aussie01's Avatar
aussie01
priming fuel lines
I am converting my 97 F350 to run on vegi oil (Frybrid kit). Part of the installation involves rerouting the fuel setup. Instead of the pump pulling the fuel from the tank, through the pump, then pushing it through the filter then to the engine, the pump is pulling the fuel from tank, to filter, through the pump then to the engine. (via fuel select solenoid) Anyway, now that this is done, I think i am having a problem with priming my lines. I have manually filled the filter housing, and also manually filled some of the lines, but still can't get it started, not even any exhaust smoke. So any tips on how to reprime my diesel lines?
Old Oct 22, 2008 | 07:01 PM
aussie01's Avatar
aussie01
problem solved.
Old Oct 22, 2008 | 07:43 PM
BlueMule's Avatar
BlueMule
Air pressure? That's how I did mine.
Old Oct 22, 2008 | 09:15 PM
aussie01's Avatar
aussie01
poor connection on elec plug near base of filter
artfd
General Diesel Discussion
19
Aug 29, 2021 08:27 AM
Dieseldriver13
Feb 10, 2013 01:17 PM
Flynndog
Oct 23, 2010 11:58 AM
baconmobile
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 9, 2007 09:18 AM
